where to hook up wasgate vac. line?
Old Aug 6, 2002 | 04:43 PM
kickz's Avatar
Default where to hook up wasgate vac. line?
hey just wanted to make sure i got it in the right place
thast just a pic .. but could someone draw it for me = P heh..
thanks
Old Aug 6, 2002 | 05:41 PM
00TurboEX's Avatar
Default Re: where to hook up wasgate vac. line? (kickz)
unless you have a boost controller, keep the 2 outlets on the turbo plugged, and run the outlet from the wastegate to any intake mani vacuum source, and that way it will hold boost til redline. hth
david
Old Aug 7, 2002 | 01:31 PM
M.A.R.C.'s Avatar
Default Re: where to hook up wasgate vac. line? (00TurboEX)
what about the same turbo... but w/ an external w/g?
Old Aug 7, 2002 | 05:27 PM
Cramerox's Avatar
Default Re: where to hook up wasgate vac. line? (CivicRyda2k)
you can tap hole on the intake arm...so your WG will read boost after your IC. it will compensate for presure drop.
OR you can Tee of a vacume source from the manifold.
Old Aug 7, 2002 | 05:30 PM
M.A.R.C.'s Avatar
Default Re: where to hook up wasgate vac. line? (Cramerox)
what about that little fitting on the compressor? plug it up? or could you run the signal from that source?
Old Aug 7, 2002 | 07:01 PM
Cramerox's Avatar
im not quite sure what your talking about?
you can tap from the FPR line, the break booster line, or tap in to the intake arm.
Old Aug 7, 2002 | 07:38 PM
M.A.R.C.'s Avatar
in the picture that he posted... u see the lil brass 2 way fitting in the compressor housing? what do i do with that hole? mine currently has nothing there. so what i find something to plug it up or put a fitting on there and then use that port as the signal for the wastegate? or is it better to use the FPR?
Old Aug 7, 2002 | 07:58 PM
Cramerox's Avatar
My educated guess would be yes you can use that as a source. Im just not to sure how reliable the source is since its so close. But hey if it works... I dont think it would matter if its from that brass fitting or FPR source.
Old Aug 7, 2002 | 08:25 PM
SlowTeg's Avatar
Ok, it's simple. The nipple off the turbo WILL work fine. The advantage to using a vacuum line off the intake manifold is that you will run slightly more boost. If you use the nipple off the turbo you will just get slightly lower boost because of the pressure drop caused by the intercooler (if u have one), because the pressure is measured before the intercooler. If you decide not to use the fitting on the turbo plug it.
-Mike
Old Aug 7, 2002 | 08:31 PM
Cramerox's Avatar
Default Re: where to hook up wasgate vac. line? (SlowTeg)
bingo....plus you dont have to run ugly tubing all over the place. If u got a boost controller then NP.
Old Aug 8, 2002 | 04:35 AM
M.A.R.C.'s Avatar
Cramerox
SlowTeg
d15bfi
May 5, 2012 03:42 AM
19_HaTcH_92
Feb 20, 2010 03:24 PM
1cammerjammer
Oct 22, 2009 10:04 PM
ebpcivicsi1234
Feb 11, 2005 06:12 AM
ATS*Mark
Aug 20, 2003 06:16 PM
