Simple Waste Gate question
Old Oct 2, 2001 | 05:39 PM
Mr. Vapor's Avatar
Default Simple Waste Gate question
Hey guys, i know i am a newbie spare my soul please!
on the wastegate, i have it installed with dump tube, i have the nipple installed on the top, but where does the vac line connect to! it says somewhere on my intake mani, but i dont see anything? can anyone help?
Old Oct 2, 2001 | 05:43 PM
TurboInteg95's Avatar
Default Re: Simple Waste Gate question (NYb16)
you have to run boost to the side port, the top port is a vent or used for some types of electronic boost controllers.
Old Oct 2, 2001 | 06:09 PM
Smashback's Avatar
Default Re: Simple Waste Gate question (TurboInteg95)
That's what I was thinking too. Does that mean you can leave the top nipple off since the side one hooks to vac src?
Old Oct 2, 2001 | 06:13 PM
Ben Huynh's Avatar
Default Re: Simple Waste Gate question (mplex2000)
If you're not using a boost controller, you leave the top port open.
Old Oct 2, 2001 | 06:29 PM
Mr. Vapor's Avatar
Default Re: Simple Waste Gate question (ben@importparts.com)
ok, so then my manual tubo xs boost controller would go where??????
and so now that i leave the top port open, i hook my vac line to the side port and then that in turn connects to where??????? (back to original question)
Old Oct 2, 2001 | 06:33 PM
Ben Huynh's Avatar
Side port goes to any vacuum source (intake manifold). Top port goes to boost controller.
Old Oct 2, 2001 | 06:44 PM
Mr. Vapor's Avatar
ok so i have to put a "T" into my intake to accomodate my wastegate?
Old Oct 2, 2001 | 06:55 PM
Ben Huynh's Avatar
Yep.
Old Oct 2, 2001 | 07:02 PM
Mr. Vapor's Avatar
ben to i cut that Vac line going into the Manifold right after the Throttle body?
Old Oct 2, 2001 | 07:09 PM
Ben Huynh's Avatar
Tee into the line from the stock FPR.
Old Oct 2, 2001 | 08:09 PM
Mr. Vapor's Avatar
ben, this would make TWO TEES in that line, is this still safe? cause my vortech already TEES into this, i wont lose vac power will i?
Old Oct 2, 2001 | 08:15 PM
Islander9407's Avatar
New User
Ben if one is using an FMU must one tap into the stock FPR before or after the point where the FMU taps into the vacuum line going to the stock FPR? Before being towards intake manifold and after is towards stock FPR. Also, can one tap into the intercooler pipe going to the throttle body or it's better to do so after the throttle body?
Old Oct 3, 2001 | 03:34 AM
Mr. Vapor's Avatar
Default Re: Simple Waste Gate question (Islander9407)
TTT
Old Oct 3, 2001 | 04:26 AM
newsense's Avatar
New User
the vac line out of the side of my wastegate runs to my turbo.....
Old Oct 3, 2001 | 04:36 AM
Mr. Vapor's Avatar
Default Re: Simple Waste Gate question (newsense)
OK, so let me get this all straight, (Correct me if i am wrong)
The line that goes to the top of the Wastegate connects to my boost controller, which then connects to my compressor
the line on the side of my wastegate (actually the rear) goes to my intake manifold
IS THIS CORRECT?
Old Oct 3, 2001 | 05:54 AM
whagkangmakulet's Avatar
I'll try to scan the Tial wastegate installation diagram.. This should answer some of your question.. i have the same question before also....I plug my compressor housing.. then tap a hole in my incooler piping for boost reading..by doing this you should get the accurate reading after the intercooler.....(correct me if i'm wrong on this one.... ) here's the diagram
http://www.kulet.com/car/Tial.jpg
[Modified by whagkangmakulet, 3:01 PM 10/3/2001]
[Modified by whagkangmakulet, 3:02 PM 10/3/2001]
2ndchirp
May 24, 2009 08:14 PM
Project_EK
Apr 22, 2009 09:13 AM
Silva Bullit DC4
Jan 17, 2008 02:06 PM
99silverbullet
Jan 3, 2004 06:28 PM
Evil DOHC
Dec 29, 2002 04:48 PM
