NGK Plug question...
Old Feb 15, 2003 | 11:39 AM
01ITR#700's Avatar
Default NGK Plug question...
I went to my local speed shop in need of some colder plugs for my Turbo ITR and I asked for some "8's" referring to the heat range I wanted for NGK plugs. They gave me R5671A-8.
I was just curious if these are the correct plugs, the # looked a bit different then what I remember. Oh and these are NGK Copper Core V-Power if that helps.
Thanks.
M
Old Feb 15, 2003 | 01:05 PM
civperc's Avatar
Default Re: NGK Plug question... (01ITR#700)
I use bkre7's in my friends' cars. They're cold enough and can be gapped w/o prob.s
I dunno about those R5671A-8's they gave you, never really heard those mentioned for Honda turbo useage anywhere before. If they're good tho, I'd like to hear some comments about them.
Old Feb 15, 2003 | 02:28 PM
camp1320.com's Avatar
the R5671A-8 and colder are used by alot of the the top Pro racers. That is a right FI plug for your turbo or supercharged set up. you can also use the common BCPR7ES-11 or the BKR7E how much did you pay for them..??
Old Feb 15, 2003 | 05:12 PM
ekb18c's Avatar
Use the bkre's or the bcp's if you are running low boost.
Low boost = 0-14psi.
Old Feb 15, 2003 | 06:41 PM
turbocoupe's Avatar
Default Re: NGK Plug question... (ekb18c)
The NGK website has a helpful chart on how to read the sparkplug #'s. You need Adobe Acrobat to view it though...
Old Feb 16, 2003 | 07:55 AM
flat-blk-HB's Avatar
Default Re: NGK Plug question... (turbocoupe)
BCPR7ES-11
will these work in a D16Y8 too??
Old Feb 16, 2003 | 08:02 AM
TurbothisLS's Avatar
use bcpr7e-11
the bkr ones are for eclipse
Old Feb 16, 2003 | 12:50 PM
01ITR#700's Avatar
Default Re: NGK Plug question... (camp1320.com)
Yeah, the guys at the shop often run these(I think) in their 500-700hp FI Honda Motors. They are pretty nice and my car idles and runs smoother then ever with these plugs. I paid $11 for the set of 4.
Thanks for the info.
M
R.S.AKIMOTO
Apr 18, 2007 09:56 AM
memorybox
Dec 31, 2006 08:58 AM
SpeedMonkeyRacing
Apr 24, 2003 08:55 PM
Prelude Vtec 23
May 25, 2002 07:40 PM
BluLuder
Jan 28, 2002 12:30 AM
