Quick Question: Installing ARP head studs....metal sleeves?
Old Nov 19, 2006 | 03:36 PM
GetawayInMoscow's Avatar
Default Quick Question: Installing ARP head studs....metal sleeves?
I'm temporarily swapping in my B16 block so I can bore out my B18C1.
I'm installing ARP head studs into the B16 and I've got a question. Where do the little metal sleeves go? The sleeves are the ones that go over the head studs and half go into the block and the other half into the head. I've only got 2, are there supposed to be 4? They can only go into the bottom 4 out of 5 holes on the head...
Please help Honda-Tech!!!
Milan
Old Nov 19, 2006 | 03:39 PM
BoostedEG6's Avatar
Default Re: Quick Question: Installing ARP head studs....metal sleeves? (GetawayInMoscow)
those are the dowl pins..... they can only go on two of the front or two of the back headstuds..... you cant mess it up.... look on the head and place them in the only two holes that they fit in same with the block
Old Nov 19, 2006 | 03:50 PM
Jared's Avatar
if you're asking questions like this then you shouldnt be swapping your own cyl head.
Old Nov 19, 2006 | 03:54 PM
Default Re: Quick Question: Installing ARP head studs....metal sleeves? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">if you're asking questions like this then you shouldnt be swapping your own cyl head.</TD></TR></TABLE>
Thanks for the vote of confidence dick.
Old Nov 19, 2006 | 04:05 PM
BoostedJeff's Avatar
while the best way to learn is to do it yourself.... this is not something you should be doing if you dont know something as simple as this.
yeah, making a post to know the tq on the cam caps... maybe
Old Nov 19, 2006 | 09:03 PM
Default Re: Quick Question: Installing ARP head studs....metal sleeves? (BoostedJeff)
Okay well everything is done. All I needed was a simple answer and I took care of everything else. No reason to insult people, it's not exactly productive.
Old Nov 19, 2006 | 09:23 PM
when did anyone insult anyone?
get the sand out of your *****
Old Nov 20, 2006 | 05:50 AM
JoePSI's Avatar
constructive criticism is not an insult, the fact that they posted even advising you to not do it, means they care enough to post about it. Hope everything goes well good luck.
Old Nov 20, 2006 | 05:57 AM
Default Re: Quick Question: Installing ARP head studs....metal sleeves? (JoePSI)
How is it constructive? How is someone supposed to learn if they can't ask questions, I just don't understand. Sure maybe it's obvious to you guys but I've never pulled my own head before. It was the first problem I ran in to and I needed a simple answer, not an opinion.
I didn't say to give your 2 cents on if you think I can do it or not, which obviously I can because I did, and I learned for next time too. Sorry I wasn't born a professional engine builder like everyone on Honda-Tech
Old Nov 20, 2006 | 06:17 AM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">How is it constructive? How is someone supposed to learn if they can't ask questions, I just don't understand. Sure maybe it's obvious to you guys but I've never pulled my own head before. It was the first problem I ran in to and I needed a simple answer, not an opinion.
I didn't say to give your 2 cents on if you think I can do it or not, which obviously I can because I did, and I learned for next time too. Sorry I wasn't born a professional engine builder like everyone on Honda-Tech </TD></TR></TABLE>
They are more or less concerned for your engine. You got your technical information along with h-t's opinion, unfortunately thats how h-t works.
Old Nov 20, 2006 | 06:18 AM
man, its something about idaho..
BoostedEG6's Avatar
get ya some
Old Nov 20, 2006 | 07:07 AM
SOHCD16y8's Avatar
Default Re: Quick Question: Installing ARP head studs....metal sleeves? (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">get ya some </TD></TR></TABLE>
lol
dcomer04
May 6, 2008 04:19 AM
gd99em1
May 14, 2007 07:08 AM
flashedDc5
Oct 25, 2006 06:32 AM
avividmemory
Dec 15, 2002 12:19 PM
