Quick 5 Bolt Turbo Question
Old Feb 11, 2010 | 02:08 PM
hondatuner020's Avatar
Default Quick 5 Bolt Turbo Question
pictured here is a inline pro cast manifold with a tial wastegate and a Turbonetics T3T4 .50 Trim 5 bolt and custom made 3 inch down pipe with waste gate dump.. will this downpipe still work with a precision SC61 5 bolt instead of that Turbonetics, keeping all other parts the same..
Old Feb 11, 2010 | 02:20 PM
boostedEF91's Avatar
Default Re: Quick 5 Bolt Turbo Question
yes.. it should work.
Old Feb 11, 2010 | 03:58 PM
anyone else?
Old Feb 11, 2010 | 03:59 PM
TheShodan's Avatar
Moderator
Edited. Turbonetics use Ford style 5 bolts, Precision uses ford style 5 bolts. Length of cartridge is the same.
Done.
Old Feb 11, 2010 | 04:21 PM
they both have ford 5 bolts so im good? your nope is throwing me...???
Old Feb 11, 2010 | 07:02 PM
helpp
Old Feb 11, 2010 | 07:22 PM
91jdmhatchback's Avatar
measure the bolt hole spacing and compare that to the turbo your looking to buy, that will tell you if you have the correct 5 bolt flange.
You need to make sure the housing size isn't to large or it may hit the block. A measuring tape will solve all your questions.
Old Feb 11, 2010 | 08:01 PM
dont have the turbo on hand..
Old Feb 12, 2010 | 01:19 AM
Well then i can't really help you. Because most can't tell the difference by looking at the the flanges if there the correct ones.
Old Feb 12, 2010 | 05:16 AM
anyone have any knowledge of these 2 turbos?
Old Feb 12, 2010 | 05:28 AM
Kyle R's Avatar
They are both t3/t4 turbos with a 5 bolt discharge bolt pattern. You shouldn't have a problem.
Old Feb 12, 2010 | 05:39 AM
kyden's Avatar
only problem i can see is if the sc61 has an S cover. then you'll have to grind away more of the block.
Old Feb 12, 2010 | 05:44 AM
Kyle R's Avatar
Yeah. I wasn't thinking about the compressor housing. You will more than likely have to shave off some of the webbing (on the block). The Inline Pro manifold positions the turbo really close to the block. The dp should bolt up just fine though.
monster_c
Apr 12, 2012 03:50 AM
Speed94
Aug 1, 2008 06:35 AM
TurboEM1
Oct 1, 2006 05:59 PM
b18cEF9
Mar 31, 2005 07:23 PM
goofball123321
Mar 8, 2004 02:41 PM
