Questions regarding turbo setup - vacuum lines and spark plugs
This is the setup:
-stock b18c1
-GT3255e turbo
-mini-ram manifold
-650 precision injectors
-precision fmic
-greddy type rs bov
-turboXS stage one manual boost controller
-tial 38mm wastegate
-3" exhaust
Here are the questions:
1. Will the bov be the only vacuum line I need to run? Someone had mentioned to me that I should get a vacuum rail, but if that is the only line, I don't see why I would need one.
2. How do I determine A.) what spark plugs to buy and B.) what gap to put them at?
Thanks in advance
-stock b18c1
-GT3255e turbo
-mini-ram manifold
-precision fmic
-greddy type rs bov
-3" exhaust
Thanks in advance
Re: Questions regarding turbo setup - vacuum lines and spark plugs
You are gonna need vacuum lines for the boost controller, wastegate, bov, and if you have a boost gauge. You probably won't need a vacuum block however.
As for the sparkplugs, NGK's are good. You may be alright using the stock heat range, but you may need to go a step or two colder. Determining that and the gap can be found while tuning and seeing what works best. You could also ask your tuner what he would suggest.
I have NGK iridium's, I believe, right now. Would it be fine to just leave these on and maybe ask my tuner if I should change while he tunes my car?
Yeah, I'm sure. But the T fittings and lines can be hidden, right? I mean hiding T fittings sounds cleaner than having a visible vacuum manifold. Or do people typically just hide these as well?
Having a dedicated vacuum source for each piece is more efficient for each piece. The v-block is sourced from the brake booster. You can hide this as well.
The big question is what is your power goal? More than likely a 7 series NGK plug will be sufficient.
My power goal is about 300hp maybe a little more....but really it is just about what my tuner determines is safe. I am not necessarily trying to ask what spark plugs I should use, but more of how do I determine what spark plugs are necessary.
yep, i bought a golden eagle vacuum manifold, and it comes with like 5 or so ports that anything that needs vacuum can be run to. and ive heard for every 100 hp go get 1 step cooler plug
So if I got a vacuum block, I would source it at the brake booster, and then everything else that needed a vacuum I would run it to the vacuum block?
People have had great success with the BK7RE plugs or what ever the plug number is. The 7 means it is one degree colder than stock, which is 6. These plugs will be good to around 500-600hp range. I believe I used BCP7RE plugs with 248whp.
Check this out
https://honda-tech.com/forums/forced-induction-16/ngk-spark-plugs-everything-you-ever-wanted-know-more-510127/
Civic Racer X 7
05-27-2007 09:07 AM
