questions about install on a jrsc
98 gsr, I will be using Hondata s200 w/ boost
http://img142.echo.cx/img142/8258/img43429wq.jpg what is #1 plug for? #2 is that the correct way to attach the IAB? Do I need to attach any vaccum lines? #3 is this hose replaced at all? #4 is this hose replaced at all? http://img142.echo.cx/img142/2403/img43441lh.jpg (This is how my project currently sits) is there anything else you notice that doesn't look correct, or needs to be done before I attach the blower to the manifold? |
I think plug 1 may be for your IAT
Re: questions about install on a jrsc (SneezR)
#1 plugs into one of the sensors on the factory black vacum box
#2 Is a chunt valve #3 Coolant line feeding the heater core so you heat inside the car #4 Coolant out for heater core Both #1 and #2 won't be needed after you do hondata.. |
#3 heater hose is supposed to be relaced(do not ruse the metal pipe)...
#4 I usually relace this hose as well Leave the IAB plugged in...do not connect any hoses to it #2 appears to be the plug for your iac valve(Not sure...gotta check the wire colors)...I dont know what they plugged it into, but generally on a jrsc kit for a gsr you have to extend those wires to reach the iac valve(the kit actually comes with a premade extension harness) |
Re: questions about install on a jrsc (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr »</TD></TR><TR><TD CLASS="quote">#1 plugs into one of the sensors on the factory black vacum box
#2 Is a chunt valve #3 Coolant line feeding the heater core so you heat inside the car #4 Coolant out for heater core Both #1 and #2 won't be needed after you do hondata..</TD></TR></TABLE> Correction..#4 is for Idle Air Control Vavle |
