Coolant bypass
Old Apr 22, 2009 | 10:43 AM
Jdmtuned's Avatar
From: Long Beach/Riverside, California, United States
Default Coolant bypass
Im running a boosted GSR setup. i have this nipple plugged. but the plug keeps on expanding and ripping. this is my third plug for it and im tired of it, because i can't go far with it. What are u guys doing to keep this plug.
Old Apr 22, 2009 | 11:46 AM
kyden's Avatar
Default Re: Coolant bypass
why not have it welded shut?
Old Apr 22, 2009 | 02:08 PM
m R g S r's Avatar
The one with the hose clamped to it? Get good coolant/fuel hose and run that port to one side of the IAC valve. The other end of the iac goes back to ghe water pipeb No need for any plug.
Old Apr 22, 2009 | 02:22 PM
HamiltonRex's Avatar
your using a vacuum cap, no wonder it keeps blowing, its not designed for what your trying to do.
Have it welded shut
Old Apr 22, 2009 | 10:03 PM
Jdmtuned's Avatar
thanks guys...i didn't think bout welding the piece until i saw that picture and figure i could take it apart from the block
Old Apr 23, 2009 | 12:20 AM
TehGhett0P1mp's Avatar
Not trying to hijack but just in for knowledge, on my car the hose on that same thing is leaking. What exactly is the purpose of that valve? Would it be better for me to run new clean hose to whereever it is going or just weld it shut like others are saying?
I dont want to mess up a system that is working correctly unless it is not needed..setup is on a stock turboed gsr just incase it matters.
Thanks again and sorry if I hijacked..
Old Apr 23, 2009 | 06:59 AM
hootiehoo's Avatar
if you dont have a welder, cut the barb off, drill it out, and tap it with an NPT thread, like 1/8 or 1/4 looks right.
Old Apr 23, 2009 | 07:12 AM
jdmitrcivic's Avatar
If you want to plug it without welding it, use a small piece of good quality hose and stick a nice fitting bolt in one end and use worm clamps to lock it down. I tried a vacuum cap, and was dry rotted befroe I even had a chance to run the engine. Good thing I noticed it before startup, could of been messy.
Old Apr 23, 2009 | 11:00 AM
redlinetuning's Avatar
It's there for a reason.
turboHondaWesJ
Dec 22, 2012 07:44 AM
ndiehm
Mar 23, 2012 05:03 PM
hotrod99
May 5, 2007 12:11 PM
94CivicSi
Aug 16, 2004 09:02 PM
speedymon
Nov 14, 2002 10:44 AM
