question on what set up would be faster?
Old Jul 14, 2003 | 10:20 AM
wu tang's Avatar
Default question on what set up would be faster?
ok...witch one would be faster. a built block d16y8 and the head would be stock. but would have some sort of boost head gasket. and yes both of these motors would have proper fuel and such. and the other motor is a ls vtec with a stock head gasket. and stock internals.
on the d16y8 i would boost 25 pounds at the track. and around 14 pounds on the ls vtec unless i can go higher. this will be going in a EF.
Old Jul 14, 2003 | 10:30 AM
Quik Chris's Avatar
Default Re: question on what set up would be faster? (wu tang)
Not enough info dude.... That's like asking- which is faster, a car or a train?
Old Jul 14, 2003 | 10:41 AM
wu tang's Avatar
Default Re: question on what set up would be faster? (Quik Chris)
im asking. witch motor set up would be faster
Old Jul 14, 2003 | 10:42 AM
wu tang's Avatar
witch one is more worth it
Old Jul 14, 2003 | 10:45 AM
mos's Avatar
mos
25lbs of boost on the d would be faster. For about ten seconds.
Old Jul 14, 2003 | 10:47 AM
madman604's Avatar
id say the 25psi civic motor, but i dont see it living very long.
id prefer to build the LS motor and turbo it. not a fan of d series motors.
Old Jul 14, 2003 | 03:36 PM
wu tang's Avatar
Default Re: question on what set up would be faster? (Turbo E)
allright, but the d-series will be able to handal it. it wont be on 25psi everyday. just on the track.
Old Jul 19, 2003 | 07:51 PM
schlack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris &raquo;</TD></TR><TR><TD CLASS="quote">Not enough info dude.... That's like asking- which is faster, a car or a train?</TD></TR></TABLE>
I would say the train is faster than this cars setup, also it would be more reliable.lol
Old Jul 19, 2003 | 08:08 PM
boostCreep's Avatar
id say u need to do more research...why not just run a open wastegate...who needs full boost...just let it flow baby
H22*CiViC
May 23, 2011 04:01 PM
kpjo4
Mar 8, 2010 11:54 AM
little white
11
Jun 11, 2008 06:26 PM
Mostecstreethb
Oct 27, 2006 08:08 PM
madcrossover
Feb 14, 2006 11:45 AM
