LS BOOST stock internals question
Old Mar 2, 2010 | 05:20 PM
kpjo4's Avatar
Default LS BOOST stock internals question
On a all stock b18b1 motor what part of the motor relatively gives out first on a boosted setup? From what I have collected I can just find out that the crank is pretty durable in the LS for boost applications
Old Mar 2, 2010 | 05:41 PM
Atreidies's Avatar
Default Re: LS BOOST stock internals question
Depends. Your head could rise which will crap your headgasket and in turn the rest of the motor. On a good tune, you risk raising your head above 15 psi or so. ARP studs will remedy that. If your tune is no good, you will have major issues quick. Also, don't raise your redline to some stupid number. Stay around stock until you can build the bottom end.
Old Mar 2, 2010 | 06:36 PM
Turbo-LS's Avatar
if you keep it around 300whp it will last you a long time. you can push it to 350 and still have reliability but not as long. anythign over that is pushign it and reliability will be out the window. also going to depend on the turbo setup and the tune. you can pop a motor easily at low power levels if its not done right
Old Mar 3, 2010 | 05:57 AM
lsvtecracer's Avatar
I just dyno a customer's car last week for IFO baton rouge and it made 283@14 psi on a bone stock turbo ls. The car ran 12.3@109 on the first pass. The factory head bolts gave out on the second pass. It's either the factory bolts or pistons that usually give out first. The customer's was going to put arp headstud for insurance, but ran out of time before the race. There's another guy that Jason (Stoopid) tune that made 309 whp @20 psi of boost. The only thing he upgraded was arp head stud. The motor has been running for years now and his quickest pass to date is 11.8.
Steve
Old Mar 3, 2010 | 06:21 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
and that same guy Jason that tuned mine, it blew up 5 min from the dyno about 7yrs ago.@ 305h@15psi
Piston ringlands go out first cause they shatter. Keep it simple. If you want more power on a stock LS upgrade the Golden Eagle head studs and run e85
Old Mar 3, 2010 | 07:36 AM
Did all 4 of your ringlands crack? My customer and his friend tore down the engine yesterday and they said only the head gasket was blown. Nothing else was really damage so i'm pretty sure the factory bolt just stretch and let water in. Head studs are the best upgrade that you can do for a factory motor on low boost.
Steve
Old Mar 3, 2010 | 08:08 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
All four cracked to much timing. Ran 415 on a stock gsr for over a yr. Tony Palo tuned and sold it to another guy still making 400 on it. But it was on e85
Old Mar 3, 2010 | 08:28 AM
Atreidies's Avatar
Just goes to show how important tuning is.
Old Mar 3, 2010 | 08:49 AM
Mutiny1's Avatar
Pistons are first to go.. i have a collection of broken/ chipped/ cracking pistons from stock LS turbo set ups..
Old Mar 3, 2010 | 10:29 AM
d16z6Tcrx's Avatar
ringlands went on mine. pump gas stock gsr round 380whp. ran great all season missed 3rd on the track went 1-2-5-3. still went 11.7
Old Mar 3, 2010 | 11:00 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Im running a stock ls t with all ebay crap making 314/280tq on 17.2lbs. keep the redline at 7k and they will take plenty of abuse.
Old Mar 7, 2010 | 12:11 PM
rat city rex's Avatar
Like said. Ringlands always go out, due to to much timing. Head studs and a good tune and you are good to go. I heard a little saying that rpm's stand for Ruins People's Motors. Less rpm's and more boost = less stress on the motor.
Old Mar 8, 2010 | 10:36 AM
Loved
Community Favorite
^ take notes people. all of that is true. lol at the rpm's acronym.
Old Mar 8, 2010 | 10:54 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
thats been out for forever and if the motor is built correctly rpm's are good
Old Mar 8, 2010 | 11:12 AM
94GSRMR's Avatar
great info ahobbs u love E85 lol
Old Mar 8, 2010 | 11:54 AM
Psychoteen101's Avatar
Honda oil pumps have never been long lasting. Id be more worried about that as a mechanical failure. Ring lands are a definite, but the proper tuning should minimize the chances of this happening. An oil pump failing wont be saved by the tune.
H22*CiViC
May 23, 2011 04:01 PM
teggyjeff
Oct 30, 2008 03:26 AM
94integragsr
Jul 27, 2005 08:06 AM
94EGcoupe
Aug 5, 2004 09:35 AM
sPaRk'iT
Nov 22, 2003 04:55 AM
