Question for tial bov users
Old Sep 11, 2004 | 03:31 PM
TurboTegB18c's Avatar
Default Question for tial bov users
I was wondering if your tial bov is open at idle? The one on my buddies car is open at idle and closes as you give it throttle. Thanks in advance for your replies. Paul
Old Sep 11, 2004 | 04:41 PM
Boosted Chemist's Avatar
Default Re: Question for tial bov users (TurboTegB18c)
yeah mine in open at idle, there is a vacuum in the intake manifold with the throttle shut. This causes it to stay open.
Old Sep 11, 2004 | 06:13 PM
PM-Performance's Avatar
Default Re: Question for tial bov users (Mad Chemist)
mine did too
Old Sep 11, 2004 | 06:54 PM
Default Re: Question for tial bov users (itr206)
Thanks for ur reply. Paul
Old Sep 11, 2004 | 06:58 PM
B18 CYA's Avatar
out of curiosity, why does a tial bovs tay open at idle? something new to me...
Old Sep 12, 2004 | 07:13 AM
Ri5e's Avatar
Default Re: (c2nap)
Because when the engine is in vacuum (idling or between shifting), the valve must be open for the pressure to release from the charge pipes.
Also on some BOV's you can adjust the valve so it's more closed (Get more compressor surge) or more open (More boost leak).
Old Sep 12, 2004 | 07:33 AM
BROOD's Avatar
It is not open at idle...and it should not be so just running at idle. Every Tial I have used would remain closed at idle..but would open slightly after you yank the throttle cable from idle.
There are two or three different springs tensions that can come in the 50mm bov.
Old Sep 12, 2004 | 07:41 AM
Dr Pooface's Avatar
Default Re: Question for tial bov users (BROOD)
Mine is always closed at idle.
Old Sep 12, 2004 | 07:48 AM
DIRep972's Avatar
Smarter than you
My vortech always ran open at idle. Im not sure how a bov would work if it didn't open under vacum and close w/ less vacum and in boost?
Old Sep 12, 2004 | 10:47 AM
J337_UNIT's Avatar
Default Re: Question for tial bov users (DIRep972)
mine is open at idle ..but as soon as u apply throttle (any percentage) it closes. i have a 7 psi spring in there .. there are 3 spring options i believe 7, 9 , and 14 psi.. YES im talking about the BOV andnot the wastegate this is how tial offeres there BOV's. thats just a message for those of you who dont know about the tial BOV's
Old Sep 12, 2004 | 10:58 AM
That's what i thought, 1 buddy has one that is closed at idle and another that is open at idle, therefore, i thought we had gotten a defective bov. For the people running the tial bov that is closed at idle, what psi spring are u running? Thanks, Paul
eg:R
Jan 31, 2007 01:27 PM
igo4bmx
Apr 12, 2005 04:45 AM
Battle Mike
Jan 6, 2005 05:45 PM
NotUrAvgSi
Sep 14, 2004 10:37 AM
_Endless_
Jul 4, 2003 10:56 AM
