QUESTION: SHAFT PLAY?
Old Sep 30, 2009 | 04:12 PM
honda_mike's Avatar
Default QUESTION: SHAFT PLAY?
Hey guys I recently just picked up basically a complete turbo kit for a good price, The turbo has a TINY bit of shaft play when u move it side to side ... how bad will it affect? will it last etc... it's not going to be on alot of boost maybe 8-9psi
Old Sep 30, 2009 | 05:16 PM
Schister66's Avatar
Man U FTW
Default Re: QUESTION: SHAFT PLAY?
Does it move up and down or does the compressor wheel want to move in and out. See picture below...Does it move like the first picture or the second.
By the way, i hope you like the picture...i made it especially for you
Old Sep 30, 2009 | 05:18 PM
Schister66's Avatar
Man U FTW
A little bit of up and down movement is normal. Its hard to explain what "a little bit is" but you get the idea. If the wheel moves in and out (like the second pic) that's not good. I forget what seals those are, but apparently they're going out. Hope this helps
Old Sep 30, 2009 | 08:50 PM
honda_mike's Avatar
Thanks I will check tommorow thanks for the help! ALSO if it is play are there any rebuild kits?
Old Sep 30, 2009 | 09:59 PM
accord_raffi's Avatar
I think the rebuildability is based on the condition of the thrust bearing? idk someone clarify that for me b/c i know there is a point where you need a whole chra.
Old Oct 1, 2009 | 05:41 AM
jhammond_82's Avatar
Reject Papi
yeah, you can get rebuild kits off ebay. i just ordered one last week as a matter of fact. type in 'minor rebuild kit'. they are fairly cheap, around 40 bucks or so for the basic kit.
Old Oct 1, 2009 | 08:21 AM
honda_mike's Avatar
thanks guys ... thanks for the pic schister
Jackrabbit4
Feb 9, 2011 02:04 PM
SOHCvtakdude
Dec 8, 2010 02:41 PM
EJ8chu
Mar 19, 2009 01:24 PM
D17alltheway
Mar 20, 2008 02:01 PM
HondaGSX
Mar 11, 2006 08:09 AM
