question regarding bore sizes
Old Sep 26, 2002 | 09:20 PM
gsr squirrel's Avatar
New User
Default question regarding bore sizes
i was just curious to know why a lot of people when getting there blocks resleeved, choose 84mm. I understand that it would then roughly be a 2.0l. But, why don't people choose to go larger, like say 87mm or 89mm? Is the block to small for this? Take into consideration i'm talking about motors with boost, not n/a.
Old Sep 26, 2002 | 11:30 PM
The sweed's Avatar
Default Re: question regarding bore sizes (gsr squirrel)
The walls betwin each cylinder get´s to thin
Old Sep 27, 2002 | 01:20 AM
VaporTrail's Avatar
New User
Default Re: question regarding bore sizes (The sweed)
for some reason, this post made me smile, while being absolutely correct. In theory at least...
Old Sep 27, 2002 | 05:04 AM
New User
Default Re: question regarding bore sizes (VaporTrail)
so lets say for example that having a b20 resleeved to be a 2.2 liter isn;t safe enough for boost? Or do different rules apply because it is already up to 2l.
Old Sep 27, 2002 | 06:24 AM
New User
ttt anyone?
Old Sep 27, 2002 | 10:06 AM
vtec69's Avatar
anyone know
Old Oct 31, 2002 | 12:52 PM
Anyotherone's Avatar
Default Re: question regarding bore sizes (vtec69)
My understanding is that the B20 is the same block as the b18 series... it has a different sleeve process (I think all 4 cyl. are cast in one piece which makes it stronger) but overall it's the same size as the b18, making a larger bore equally "dangerous".
Old Oct 31, 2002 | 07:25 PM
Quick 200k Mile Motor's Avatar
yup, the Width of material between each cylinder gets too small ..like a *****
Old Oct 31, 2002 | 10:58 PM
highbrid's Avatar
Default Re: question regarding bore sizes (Quick 200k Mile Motor)
I had a gsr that was bored to 86mm, those walls were super thin. I could not imagine anything beyond that. Although there are supposedly a few guys running 87mm bores...on the street. Get that thing stroked a bit, say 100mm stroke, and youve got yourself a 300hp all motor monster. I chose to go with the 83mm bore on my gsr. There is plenty of wall left with the gem sleeves, and i will be boosting on it.
Old Feb 1, 2005 | 02:35 AM
jde_07's Avatar
Default Re: question regarding bore sizes (highbrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr squirrel &raquo;</TD></TR><TR><TD CLASS="quote">so lets say for example that having a b20 resleeved to be a 2.2 liter isn;t safe enough for boost? Or do different rules apply because it is already up to 2l.</TD></TR></TABLE>
You don't just get displacement out of the bore size. you can change your crank throw and that can also give you more displacement. You can go to a 2.2L if you run an 84mm piston with a stroker crank and rods. I have a friend that is building a this type of motor down in fort collins.
Old Feb 1, 2005 | 07:00 AM
New User
Default Re: question regarding bore sizes (jde_07)
holy hell! talking about bringing up a topic from the dead. this thread is over 2 years old. =P
1990IntegraLS
Jan 7, 2016 05:27 PM
Boostinb20!
Nov 24, 2008 03:44 PM
QB21
Jul 22, 2005 06:21 AM
v.i.gsr
Dec 16, 2004 01:15 PM
