B20 with 85mm Bore is this safe for high Boost
Old Nov 24, 2008 | 04:47 AM
Boostinb20!'s Avatar
Icon3 B20 with 85mm Bore is this safe for high Boost
So here it is I currently have a B20 Block sleeved and im making about 550Hp at the wheels its all fine and dandy however the rings have died and there is a scratch in one of the sleeves. I am looking to see if i punch it out to a 85mm Bore is this safe or am I likely to pop head gaskets more often then not. The Block is sleeved by golden eagle and rate at high PSI no worried so much about sleeves rather then the head gaskets.HOPE YOU CAN HELP
Old Nov 24, 2008 | 05:04 AM
black_EM1's Avatar
Community Builder
Community Influencer
From what I've gathered, I may be incorrect, but you'll have HG sealing issues at 85mm.
I might be mistaken, though.
Old Nov 24, 2008 | 05:15 AM
Yeah I have heard the Magic number for high boost is 83mm but im trying to stay away from having it resleeved again. but if im going to run into more issues them im not sure.
Old Nov 24, 2008 | 05:25 AM
black_EM1's Avatar
Community Builder
Funny, I've heard 84mm.
:shrugs:
Old Nov 24, 2008 | 05:27 AM
sgnlab's Avatar
83mm ftmfw
Old Nov 24, 2008 | 05:33 AM
So im gathering to go ahead and resleeve it and stay away from 85mm bore there was another post that was written and people have been suceddful but we all know how that goes no two motors are the same.
Old Nov 24, 2008 | 05:38 AM
miller's Avatar
You will be fine at 85mm with as much boost as you want as long as you a tuner that has an idea.
Old Nov 24, 2008 | 05:43 AM
Can you Elaborate on that a little for me. have you had success or just heard horror stories there alot of torque gain with this just not alot room for error before a head gasket goes.
Old Nov 24, 2008 | 06:39 AM
miller's Avatar
As far as power gains go, i am not to sure if it will make a huge noticeable difference over persay an 84mm setup. The one thing i will tell you is that 85mm on a b series engine is not to big of a bore for boost. I have tuned alot of high hp b series engines that are 85mm and they are just fine. No issues of headgaskets or anything like you are thinking.
Old Nov 24, 2008 | 07:08 AM
tony1's Avatar
We've made 1100whp on an 85mm b series, no worries. I wouldn't go any bigger, but you'll be fine at 85mm.
Old Nov 24, 2008 | 07:15 AM
Is there much of a HP loss of io decide to run a 83mm piston in there I ahve only ran 84 so far on all my motors. most made was 595hp on 50/50 mix of gas c16 and 92 octance pump gas mixture at 23 poubds of boost with GSR cams
Old Nov 24, 2008 | 01:23 PM
CerealKiller's Avatar
85.mm should be fine for high boost.
Old Nov 24, 2008 | 03:44 PM
DC4KiD's Avatar
It will be fine.
DelSlow_JDM
Oct 2, 2009 09:26 PM
Ct4754
Oct 11, 2008 06:24 PM
countryboy
Sep 15, 2004 07:06 PM
TwistedHatch
Apr 21, 2003 11:44 AM
MartGSR
Oct 15, 2002 09:35 AM
