Quaife install question
Old May 12, 2003 | 06:19 AM
Bnjmn's Avatar
Default Quaife install question
When installing a quaife LSD is it necessary to check the pre-load on the tapered roller bearings? If so is the pre-load tool available at regular car parts stores?
Thanks
Ben
Modified by Bnjmn at 10:18 AM 5/13/2003
Old May 13, 2003 | 06:19 AM
Bnjmn's Avatar
Default Re: Quaife install question (Bnjmn)
up...
Old May 13, 2003 | 06:55 AM
Scott - 93HB Si's Avatar
I didn't when I installed mine, but then again, i have a B16A2 tranny. If you have tapered roller bearings then you probably have an ITR tranny.
I'm not sure if you reuse teh roller bearings, or you could just get regular B16A2 Ball bearings (from B16A2 tranny).
Old May 13, 2003 | 08:30 AM
Bnjmn's Avatar
Default Re: Quaife install question (Scott - 93HB Si)
According to the 1994 Helms for a GSR, there are tapered roller bearings.
Anyone else have experience with a GSR tranny?
Thanks
Ben
miyagi
Apr 20, 2006 11:55 AM
mingchi69
Feb 17, 2004 09:39 AM
The_Head
Aug 30, 2002 01:28 PM
SlowTeg
Aug 6, 2002 08:06 PM
