what causes white smoke on start-up ??
Old 01-26-2007, 07:55 PM
Cyber ITR's Avatar
Default what causes white smoke on start-up ??
hey guys
well today is actually the first time i found out that my car blows white smoke on start up just for like 2-3 secs after its been sitting like 30mins of so, its not a lot of white smoke but its enough to see that there's actually smokes coming out of the tail pipe
i just recently changed the oil and hosed off the engine bay
my spark plugs looks nice and dry
on my old oil there was no sign of coolant present
can anyone help me and make my day please
thanks guys
Old 01-26-2007, 07:57 PM
iBrandon's Avatar
Default Re: what causes white smoke on start-up ?? (Cyber ITR)
condensation burning off?
Old 01-26-2007, 08:02 PM
Cyber ITR's Avatar
Default Re: what causes white smoke on start-up ?? (iBrandon)
nah i know for sure its not condensation
its summer where i live at the moment
its like first time i start up the car in the morning it would smoke for like 2-3 secs then stops....... drive the car ........ park the car for say 30mins...... start it up...... white smoke comes out again
Old 01-26-2007, 08:34 PM
lakai_19's Avatar
headgasket might be starting to go?? that happend to mine just alittle white on start up and it turned out to be my headgasket coolent was leaking in to the cylanders and burning and making it smoke white
Old 01-26-2007, 08:44 PM
Cyber ITR's Avatar
Default Re: (lakai_19)
if its headgasket, shouldnt i be losing water ???
my water level stays the same
Old 01-26-2007, 08:48 PM
lakai_19's Avatar
is the coolent fogy? open your oil cap and look at the oil cap and see if it looks creamy it might be the very begining stage of gasket problems but i might be wrong hopfully but thats the only thing i can think of
Old 01-26-2007, 08:51 PM
Cyber ITR's Avatar
nope, on the bottom of my oil cap theres no milky colour at all
my radiator cap looks clean, and the water also still clean green
do you think its got something to do from me cleaning the engine bay with garden hose ???
doubt it tho .....
cnofused confused help help help
Old 01-26-2007, 09:02 PM
lakai_19's Avatar
did you cover your turbo? and you said it only started smoking after you sprayed it?
Old 01-26-2007, 09:17 PM
Cyber ITR's Avatar
yupe i covered my turbo, dizzy cap, ext coil, cdi ignition even the battery
all covered with plastic bags
i just went for a drive giving it hell, car pulls hard still
and from personal experience if i had a blown headgasket the water in the resevoir bottle should be all the way full right ??
but i just checked, it stays the same
Old 01-26-2007, 09:23 PM
lakai_19's Avatar
hm then im not sure dude sorry wish i could help
Old 01-26-2007, 09:24 PM
Cyber ITR's Avatar
haha thanks for the time uve spent trying to help me tho
much appreciated
****** cars
Old 01-26-2007, 09:29 PM
Cyber ITR's Avatar
Default Re: (Cyber ITR)
one more question
say your right and my headgasket is on the way out, will it shows if i do leakdown test ???
lakai_19's Avatar
anytime
Old 01-26-2007, 09:30 PM
lakai_19's Avatar
you should be able to tell yes
Old 01-26-2007, 09:55 PM
Cyber ITR's Avatar
sweet
bumpage for more opinions
Old 01-26-2007, 10:25 PM
turbocivic22's Avatar
check your oil return line. mine used to do the same thing. when i first started it there would be white smoke but then it would go away. my return line was crimped a little.
Old 01-26-2007, 11:13 PM
Cyber ITR's Avatar
Default Re: (turbocivic22)
the oil return line for the turbo ??
sorry not really mechanically minded person
Old 01-27-2007, 12:18 AM
ExospeedAMcrx's Avatar
edit... read your post wrong.
Old 01-27-2007, 11:21 AM
yes the oil return 4 the turbo
Old 01-27-2007, 11:28 AM
Fitti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR &raquo;</TD></TR><TR><TD CLASS="quote">the oil return line for the turbo ??
sorry not really mechanically minded person </TD></TR></TABLE>
The oil return is where the turbo drains the oil back into the oil pan.
They are saying to check that and see if there is a rescrition in the line that could be cause the oil to back up.
Yes a leak down can tell you quite a few things about the motor including where the motor is leaking from if it's leaking
Old 01-27-2007, 07:40 PM
97grnrs's Avatar
Default Re: (Fitti)
possibly valve stem seals.. mine used to do that then i replaced all 16 and no more white smoke every time it started
Old 01-27-2007, 07:43 PM
Cyber ITR's Avatar
Default Re: (97grnrs)
your car used to smoke just for a couple secs on each time u started it ??
the damn engine was built with new gaskets and seals not long ago ......
Old 01-28-2007, 12:30 AM
Cyber ITR's Avatar
up
Old 01-28-2007, 07:55 PM
Cyber ITR's Avatar
bump
i started up the car and the white smoke doesnt have that sweet-coolant-burning smell
im really confused
when i washed the engine bay i sprayed degreaser all over the place, would it be some unwashed degreaser burning off ?? dont think so
HELPP !!!!
Old 01-31-2007, 12:50 AM
StreetracerVL's Avatar
Have the exact same problem. My oil drain is fine and I am not losing any coolant either, we're in the same boat
The funny thing is, I also degreased my engine bay not too long ago Smoke was present before though so yea that can't be it. Bump for some more opinions!
Quick Reply: what causes white smoke on start-up ??
