Psi levels
Old Jun 21, 2006 | 01:46 AM
rosco's Avatar
Default Psi levels
hey guys, yet another noob question as Iam new here iv done some googling and i couldnt find an explination so here goes.
You turbo your lets say b16b how do u modify what psi your running? is there a valve? or what or does the turbo you buy come pre set?
Sorry for dumb question just intrested to find out.
Old Jun 21, 2006 | 05:34 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Psi levels (rosco)
you get a wastegate with the lowest spring that you want to run as a base. then you get some kind of boost controller to adjust it higher from there.
Old Jun 21, 2006 | 05:36 AM
nota-eg's Avatar
Default Re: Psi levels (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">you get a wastegate with the lowest spring that you want to run as a base. then you get some kind of boost controller to adjust it higher from there.</TD></TR></TABLE>
Exactly.
Some turbos also have what's called an internal wastegate that comes built into the turbo. To increase the boost you just get a boost controller and connect it inline with the vacuum line to your wastegate.
My turbo came stock running 7lbs. I bought a boost controller and stuck it inline with the vacuum to the wastegate and when I turn a screw on it it will increase or decrease the boost. I'm now running 15psi on the same turbo.
Old Jun 21, 2006 | 04:28 PM
rosco's Avatar
Sweet man, Iv been looking at a Turbonetics Turbo Kit, http://www.prostreetonline.com..._kits/
as it says its set to 9psi standard inless specifid its an external wastegate tho would this mean i could not do the same idea as you? or can i get a boost controller and it will work fine?
Sorry for the noob questions just as we were on the matter .
Old Jun 21, 2006 | 07:33 PM
Mr. Badwrench
Default Re: (rosco)
witht he wastegate in that kit, if you run the vac line from the compressor to the gate, the car will run 9 psi -+ 1-2 all the time, depending on the atmospheric pressure. so with that setup, the least you can run is 9. then a controller will be able to increase up from there.
Old Jun 21, 2006 | 07:40 PM
noboostedEGo's Avatar
Default Re: (boostedcivicsir)
Yup yup, ^^what he said. Actually, many people prefer external wastegate (like in that kit) anyways. It's nice because boost is regulated before the turbo, so it's more reliable in a sense. Less fluctuation in boost generally, a nice boost controller will help with consistency also.
95srv
May 12, 2006 07:09 AM
mrx
Dec 26, 2005 10:43 AM
hatchracer02
Jan 10, 2005 05:13 AM
sirb18a
Oct 19, 2003 01:49 PM
92SiB18C1
Nov 30, 2002 06:34 AM
