PSI!!!!!!!!!!!!
Old Jul 17, 2001 | 06:04 PM
Drboosted's Avatar
New User
Default PSI!!!!!!!!!!!!
I have a 97 LS, the whole bottom end is built 9:1 . I have 440cc rc's, a 255 lph fuel pump, fuel regulater, and a FMU. I was wondering what is the most boost i can run on 94 octane and maybe a octane booster. I was told 15 Psi. If any one has any info please let me know.
thanks
Drboosted
Old Jul 17, 2001 | 06:05 PM
Drboosted's Avatar
New User
Default Re: PSI!!!!!!!!!!!! (Drboosted)
I forgot the most important i also have a Apexi Afc
thanks
Old Jul 17, 2001 | 09:11 PM
TurboInteg95's Avatar
It's really not a good idea to have that pump with an FMU. they cant take the pressure.
Old Jul 17, 2001 | 11:13 PM
Mikex25's Avatar
New User
Default Re: PSI!!!!!!!!!!!! (TurboInteg95)
what do you mean you shoudn't use a fuel pump with a FMU? doesn't DRAG kits come with FMU and fuel pump though?
Old Jul 18, 2001 | 09:24 AM
dustin's Avatar
Default Re: PSI!!!!!!!!!!!! (Mikex25)
He means that /particular/ pump.
Old Jul 18, 2001 | 09:36 AM
Evil DOHC's Avatar
Default Re: PSI!!!!!!!!!!!! (dustin)
I suggest you check this out http://www.hondata.com/tech.html
That should help you determine that 15 psi on the stock ecu is very hard to achieve. The most restrictive part on the engine is the map sensor. 3 bar map sensor can cure all your problems.
EVIL
cheeky ode
Aug 2, 2013 07:54 AM
Novtecdohc
Feb 16, 2006 03:26 PM
hotboi850
Aug 15, 2003 06:23 PM
ATgrills.com
Sep 20, 2002 08:59 AM
Dravis
Oct 9, 2001 02:32 PM
