BEST INLINE FUEL PUMP
Old Aug 2, 2003 | 08:23 PM
hotboi850's Avatar
Default BEST INLINE FUEL PUMP
*****12:1 fmu, stock injectors, wastegate is set at .4bar(6psi) may run at 7 using boost controller*****
I've done the searches on fuel pumps and I'm sure im gonna go with an inline fuel pump but which one is the best?
Where can i get them? Summit has some but which brand is best to provide enough psi?
By doing the math. 12 x 7psi = 84psi
then add 84 + stock pressure I believe around 40psi max = 124psi
So i need minimal of 125psi fuel pump. Correct?
Any suggestions???
Anyone know where i can get the airtec inline pump from the drag kits?
Modified by hotboi850 at 5:45 AM 8/3/2003
Old Aug 2, 2003 | 09:19 PM
mskibbz-T's Avatar
Default Re: BEST INLINE FUEL PUMP (hotboi850)
why not just get a Walbro 255lph in tank high pressure fuel pump?
Old Aug 2, 2003 | 09:22 PM
hotboi850's Avatar
Default Re: BEST INLINE FUEL PUMP (mskibbz-T)
I've done my research. I heard they dont provide enough psi for an FMU.
thanks
Old Aug 2, 2003 | 09:24 PM
Bspec18's Avatar
Just use a MSD inline it will support it i'm using it myself. The walbro 255lph hp is a really good intank i have one too but it cannot support the needs of an FMU alone. Remember to use a relay when wiring the inline pump. good luck
Old Aug 15, 2003 | 06:23 PM
spooned out's Avatar
does anyone knoe if a 255 wablro fuel pump will work for a 88 crx si? i have one from my 95 si but want to knoe if i can use it for my 88 crx si, and does anyone knoe how to change it in the 88si?
cheeky ode
Aug 2, 2013 07:54 AM
KevronsEG
Jul 21, 2002 01:43 PM
b18tdelsol
May 19, 2002 07:09 PM
DeeJay
Oct 31, 2001 09:24 PM
Teluan
Sep 4, 2001 08:56 PM
