PROS and CONS>>>>>
Old Apr 13, 2007 | 08:55 AM
jarven093's Avatar
Default PROS and CONS>>>>>
What are the pros and cons for a block guard??????? can you run more boost with them or will they cause and over heating problem dose any one know anything about these???
Old Apr 13, 2007 | 09:27 AM
Untengijutsu's Avatar
Default Re: PROS and CONS>>>>> (jarven093)
Do a search ...
And you will realize that their is no real answer ...
Old Apr 13, 2007 | 09:34 AM
jdizzle!
Guest
Posts: n/a
Default Re: PROS and CONS>>>>> (Untengijutsu)
Old Apr 13, 2007 | 09:47 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: PROS and CONS>>>>> (dudebro)
well there arent really any more pro's with the block sleeving and tuning options out there. most good tuners will tell you, leave it out.
so, with that said if you still want to use one, remove the engine, install it, THEN HONE IT. it stresses the sleeves a little and makes the bore not true.
93gsr4dr
Feb 18, 2010 06:36 AM
FMIDRC Racer
Feb 14, 2005 11:48 AM
chris@cfranklins
Oct 13, 2003 09:02 PM
Aeka GSR
Sep 19, 2003 11:53 PM
BlwnBlue
Jan 19, 2002 08:44 AM
