charge piping size question.
Old Nov 15, 2008 | 11:03 AM
jbell's Avatar
Default charge piping size question.
lets assume your blower has a 50mm connection for the charge pipe
your intercooler has 2.5"
and throttle body is 67mm
any recommendations on what size piping to run, and where to step sizes?
aiming for a 10psi setup, yielding 400hp. loosing minimal pressure is important.
Old Nov 15, 2008 | 11:05 AM
96 GSR-T's Avatar
Default Re: charge piping size question. (jbell)
since you have a 2" outlet on your turbo you could just run 2" piping to the Intercooler and step it up there and run 2.5" to the TB, how I use to have my old setup done.
Old Nov 15, 2008 | 11:40 AM
GSROWNSU's Avatar
i have 2" piping from my compressor to the ic and then 2.5" piping from the intercooler to the tb. Making 360whp on 16 psi from a 57 trim. I think the 2" section of piping along with a fairly small ic was starting to choke me up a bit.
Old Nov 15, 2008 | 11:42 AM
jbell's Avatar
Default Re: (GSROWNSU)
running a lower psi (10) should prevent me from experiencing that choke, right?
Old Nov 15, 2008 | 12:54 PM
jbell's Avatar
Default Re: (jbell)
67mm tb, is that a 3" coupler?
ghettochild
Aug 10, 2004 07:02 PM
Sinner
Oct 13, 2003 11:30 AM
HuskerHybrid
Jul 10, 2003 11:38 AM
i3oricua
Mar 31, 2003 05:28 PM
DIY_Racing
Dec 26, 2002 08:59 AM
