Program Switcher
Old Apr 14, 2007 | 10:28 AM
b18_racer805's Avatar
Default Program Switcher
just seeing if this would good to use or if its possible to use with hondata to switch the maps from a race map to street when driving around town. how many people out there have used this
Old Apr 14, 2007 | 12:38 PM
ANYONE
Old Apr 14, 2007 | 01:00 PM
twkdCD595's Avatar
Default Re: (b18_racer805)
very interesting... bump for the OP.
this could be useful for running a pump gas tune and a race gas tune on systems that dont have provisions for map switching.
Old Apr 14, 2007 | 02:02 PM
adseguy's Avatar
Default Re: Program Switcher (b18_racer805)
I haven't used it since I don't see how hard it is to switch a $2 chip rather then this more expensive option. Race/Street tunes really shouldn't be different.
When I tune for Race gas and pump gas I just give the person 2 chips with proper labels.
Old Apr 14, 2007 | 03:43 PM
Dueceification's Avatar
You can use it. It is easier then switching chips. You must use a 512k chip. I have something similar on my car. It does not work on the fly you have to turn off the car before hitting the switch. Its a inexpensive way to make life easier but like adseguy said switching chips is not hard. It's really up to you if its worth it or not.
Old Apr 14, 2007 | 03:50 PM
twkdCD595's Avatar
Default Re: Program Switcher (93b16hatch)
So I guess if you dont want to pull apart the interior to change a chip (kinda inconvient) this could be slightly useful for going back and forth between pump and race gas tunes.
I asume this could work with hondata then, well the s200 that is? Too bad I want to go to the s300 before too awful long.
Old Apr 14, 2007 | 06:19 PM
Default Re: Program Switcher (twkdCD595)
I seen this part running for like 30bucks if I use this I must use 512k chip where can that be found
Old Apr 14, 2007 | 06:36 PM
akira712's Avatar
the same place your gonna get the 2timer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_racer805 &raquo;</TD></TR><TR><TD CLASS="quote">I seen this part running for like 30bucks if I use this I must use 512k chip where can that be found</TD></TR></TABLE>
Old Apr 14, 2007 | 08:26 PM
melovesboost's Avatar
or if you have S300 and just load up your race map if you have your own laptop.
civic-r11
Dec 29, 2010 12:23 PM
turbo-crx
Nov 26, 2008 11:39 AM
B17aTrbo
Feb 16, 2005 09:16 PM
Nextelbuddy
May 5, 2004 10:53 PM
TurboJesse
Sep 8, 2003 03:34 PM
