profec b stopped working?
Old Sep 23, 2004 | 03:27 PM
aemciv's Avatar
Default profec b stopped working?
Today I changed my oil and changed my coolant. I did not unplug my battery or anything electrical. I got everything done so I took my car for a test drive. I put it on high boost and go to boost and it wont go past .6 bar, its suppose to go to about 1 bar. I tried unplugging the harnesses going into the controller, leaving the ***** set to 0 and then plugging them in. nothing. could this be a vaccum line issue? however it holds the .6 bar pretty well. Is there another way to reset the controller? I think I had this problem when I first got it but I cant remember how I got it. I have the greddy profec b spec 1 controller.
thanks
Prose
Old Sep 23, 2004 | 05:02 PM
aemciv's Avatar
Default Re: profec b stopped working? (aemciv)
someone has to know how to reset the controller or how you initially set it up
thanks
prose
Old Sep 23, 2004 | 05:08 PM
DRAGLS's Avatar
there is no reset on the unit! all you do is set up the dip switches on the back and set up the amount of boost u want.
Old Sep 23, 2004 | 05:34 PM
aemciv's Avatar
Default Re: profec b stopped working? (DRAGLS)
so why is it not letting me boost over .6 bar. I have the dip switches set for internal wastegate? It has been working for over a year now. I dont see what happened?
prose
Old Sep 24, 2004 | 08:37 AM
aemciv's Avatar
can anyone help me out here? I tried to set the low and the high and nothing. the highest it will let me set both of them is .6 bar, what is the deal. is it possibly not the boost controller thats messing up?
thanks
matt
Old Sep 24, 2004 | 08:47 AM
Boltz's Avatar
Default Re: (aemciv)
Check the electrical connection to the profec?
Check all of the vacuum lines related to the profec?
Also, what psi level is the wastegate (alone) set for?
Old Sep 24, 2004 | 09:03 AM
aemciv's Avatar
the wires are good and so are the vacuum lines. the actuator is set to 5 psi. but like I said it just recently happened. I had lo set to .7 and high set to 1.0. if I turn it off the stock 5 psi will boost, then when I turn it on it wont go past .6 bar. I turn the ***** on the profec and it wont increase at all.
could I have a leak in the piping?
I would think that it wouldnt boost at all though
matt
Old Sep 24, 2004 | 09:22 AM
aemciv's Avatar
problem solved. I just had to set the switches on the back to off and then reset them to acutator. and its up and running now.
thanks for your help
prose
94lsboost
May 30, 2005 09:35 AM
chihuahuamanx
Dec 7, 2004 05:06 PM
wonny
May 29, 2002 08:11 AM
austrian type-R
Mar 14, 2002 07:11 PM
