AVC-R settings?
Old Mar 13, 2002 | 12:06 PM
austrian type-R's Avatar
Default AVC-R settings?
I´m a bit confused about the setting. I have chosen 1 Bar boost with 47% duty and the boost climbs up to 1.15 Bar. When I adjust the duty to 60, boost is building up slower and is hitting only 0.8 Bar or so. I don´t get why the boost is building lower. Shouls´nt the wg completly be closed until a setted amount of boost is reached. When I set the duty percents lower than 47, boost is going up to 1.6 Bar and wiered is that the boost setting has no affect then. I can set 0.2 Bar max boost with duty 33 %, but it climbs up to 1.5 Bar. I think when I can go lower than 47 % boost is building quicker, or not?!?!?!?!
All I want is a completly closed wg, so that I can reach my setted boost as soon as possible. How can I do this.
Old Mar 13, 2002 | 12:18 PM
LsTurbo91's Avatar
Default Re: AVC-R settings? (austrian type-R)
There's a setting called F/B Speed under the settings menu to give feedback if you want the boost faster- raise it and slower - lower it. You can also disable it and will go based on the rpm duty cyle that it learns.
Old Mar 14, 2002 | 07:11 PM
98civicEX's Avatar
Default Re: AVC-R settings? (LsTurbo91)
ohh yes, need a site that explains the AVCR in better details then the manual....anyone have any tips?
Jaesung
Dec 17, 2003 07:44 PM
wonny
May 29, 2002 08:11 AM
turbopanda
May 24, 2002 01:42 PM
Boostin Si
Jul 28, 2001 11:47 AM
