Profec B installation
Old Jan 3, 2002 | 11:43 AM
td04civic's Avatar
Default Profec B installation
I just have a question about installing the vacuum line to the intercooler pipe.
Do I install it before or after the blow off valve? thanks alot.
Old Jan 3, 2002 | 12:03 PM
adam's Avatar
Default Re: Profec B installation (td04civic)
before
mine is actually on the turbo itself, there's a side exit port on the compressor housing
Old Jan 3, 2002 | 12:24 PM
boost killz's Avatar
New User
Default Re: Profec B installation (adam)
Td04 I explained before dude.. If you look at the lower side of the compressor that port located on the bottom..use that as the pressure source .....Connect the hose to that port to go into your "IN" portion of the motor for the profec. Should be cake man.! Good luck,
Nick
L0co
Apr 11, 2014 05:29 PM
Blazin Civic
Mar 25, 2005 10:44 PM
pissedoffsol
Mar 26, 2004 07:04 PM
ProjectLudeSiR
Nov 19, 2003 08:27 PM
shadowdawn
Jun 18, 2003 03:33 PM
