tuning a turbo b18c1 using hondata s200 questions
I have a mild built b18c1 turbo motor, and i have a hondata s200. I am a nooby to this system and need to know some info about it, First off how is it connected to the ECU? Do i need a chip in ym ecu that has a socket for the s200 box? Also where do you purchase that? Then do i need anything else to be able to tune it. I have done searches but i just want to make sure i have evrything i need also i want to make sure i set it up right the first time. thanks for the help.
Yes you do need to socket the ecu you have, any hondata dealer should be able to do it. As for tuning it, just spend the money and get a Hondata certified shop to tune it on a dyno. That is the only way to get it done right.
SJdc5
02-17-2006 11:46 AM
Hoosier Daddy
12-20-2003 11:00 PM
