Problem with my car :-(
Old Sep 12, 2009 | 01:17 PM
Wuman's Avatar
Default Problem with my car :-(
I have a problem with my civic. Fully built b16 turbo.
When i go full throttle the car has no power. Exhaust sounds like there is a problem with the ignition. I cheked the spark plugs and the distributor. Everything is OK.
When i pudh down the pedal 50% ( not full throttle) the car runs good. Full boost and everything ist ok. Only when i go full throttle the car has no power but full boost :-(
Maybe someone has a idee. And sorry for my bad english
Greetings from germany
Thanks
Old Sep 12, 2009 | 02:01 PM
LightningTeg's Avatar
Community Builder
Default Re: Problem with my car :-(
Boost leak? Even a small one can build boost but it will be underpowered
Old Sep 12, 2009 | 02:15 PM
turbosleepa's Avatar
make sure your piping is hooked up, a hose may have come off
Old Sep 12, 2009 | 02:21 PM
tokesGTR's Avatar
Obvious first question is are you seeing boost on the gauge?
I'd guess something like a missfire though, check your plugs.
Old Sep 12, 2009 | 02:42 PM
Wuman's Avatar
yes boost is there.
i have changed the spark plugs. Everything OK
Old Sep 12, 2009 | 11:59 PM
tokesGTR's Avatar
You've changed the plugs, but what are they gapped at? What heat range? How old is your distributor and ignitor? What does your tune look like?
Old Sep 13, 2009 | 01:14 AM
SD_Lurker's Avatar
HT White Ops
Is the car properly tuned?
Old Sep 13, 2009 | 01:45 AM
Boosted_B_Series's Avatar
x2
Old Sep 13, 2009 | 12:13 PM
cjordan's Avatar
x3
Old Sep 13, 2009 | 12:20 PM
Wuman's Avatar
Yes the car is tuned. Runs good 10.000 kilometers. No problem. Then for one day to another this problem.
Old Sep 13, 2009 | 07:02 PM
cadeMFjohnson's Avatar
im having the same problem but i haven't gotten a wideband yet to check it out. its goin on the dyno this week to get squared away but until then i just enjoy the sound of half throttle lol
skuded
Nov 18, 2010 07:56 AM
wantasol
Engine Management and Tuning
11
Jan 8, 2010 03:01 AM
1990si
May 14, 2007 08:47 PM
crispydee
Mar 28, 2005 05:50 AM
QUICKERSILV3R
Dec 28, 2003 06:24 AM
