Post up your stock B16 setup and numbers.
Im about to put a stock B16A2 in my 92 CX. I already have everything I need to boost except a turbo. I would like to see what turbo your running on your setup and some numbers. Post dynos and pics if you have em. Thanks.
sh!t happens.
Re: Post up your stock B16 setup and numbers. (jdmtegra666)
Stock JDMB16 330WHP 220tq @12psi -OLD SETUP
Inline pro manifold
3inch dp
38mm wastegate
SC61 76trim
Precision 600whp intercooler
Hondata then I switch to AEM EMS
Inline pro manifold
3inch dp
38mm wastegate
SC61 76trim
Re: Post up your stock B16 setup and numbers. (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT »</TD></TR><TR><TD CLASS="quote">Stock JDMB16 330WHP 220tq @12psi -OLD SETUP
Inline pro manifold
3inch dp
38mm wastegate
SC61 76trim
Hondata then I switch to AEM EMS</TD></TR></TABLE>
How much total timing were you running on this? @12psi? what about @7.5psi?
Inline pro manifold
3inch dp
38mm wastegate
SC61 76trim
Hate to say search but there has been tons of threads with lots of info if you would just search for "b16 turbo". I should know, i've answered a ton of them.
Re: Post up your stock B16 setup and numbers. (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Hate to say search but there has been tons of threads with lots of info if you would just search for "b16 turbo". I should know, i've answered a ton of them.</TD></TR></TABLE>
I thought it would be good to start a thread with lots of info, instead od a hundred threads with a little info. Like the B18a/b turbo thread.
Inline pro manifold
3inch dp
38mm wastegate
SC61 76trim
Hmmmm, so I guess 300whp is not out of the question.
Inline pro manifold
3inch dp
38mm wastegate
SC61 76trim
search like nsxmatt said
https://honda-tech.com/zerothread?id=1365747
my setup is on my sig
stock b16a 2nd gen
stock b16a 2nd gen
red_hatchback
05-30-2007 10:56 AM
