is it possible to only leak oil after a hard run?
im pretty sure i have an oil leak, because while moving my car out of parking i saw a fresh oil stain (unless they look fresh for a few days then it might be my mothers lexus?) this morning, i didnt see any oil on the ground where i parked. maybe increased oil pressure or temperature while running makes it possible to go thru small cracks that are otherwise sealed?
Re: is it possible to only leak oil after a hard run? (sushibug)
its possible. But i would just lay some carboard down on the ground after a hard run and then see if it leaks on the cardboard.
Re: is it possible to only leak oil after a hard run? (b18bturbo)
thats what happens when you grow up in the 80s with big v8s that use to guzzle the oil and gas...
jbsmith
07-06-2004 04:44 PM
