Piston to Cylinder clearance wrong?
Old May 13, 2003 | 12:06 PM
B20LS-T's Avatar
New User
Default Piston to Cylinder clearance wrong?
I just got my block back from GE and they bored and honed it using endyn pistons with a bore of 84.5 mm and when I went to measure for the piston to cylinder wall clearance it came out to only .0009". I measured the cylinder bore which came out to 3.3256" and then measured the piston diameter towards the bottom which measured 3.3247", which gave me my answer. The clearance is supposed to be .0028-.0029". Am I doing something wrong. Let me know what to do. I hope I dont have to bore the cylinders more.
Old May 13, 2003 | 01:40 PM
T-sohctec's Avatar
Default Re: Piston to Cylinder clearance wrong? (B20LS-T)
That is some tight *** clearance for forged pistons.
Is you mic calibrated?
I measure my pistons @ about halfway from the bottom of the skirt to the top of the first oil ring. if you are coming up with a tight clearnce on all the pistons it's likely that they fucked up.
worst case you can hone that much out with a stone. it's not that big of a deal. did you try to fit your rings in the bore? are they hella tight as well?
Old May 13, 2003 | 01:45 PM
b18bturbo's Avatar
Default Re: Piston to Cylinder clearance wrong? (T-sohctec)
yeah this happend to me as well just had to hone it out slightly to get the correct spec.
Old May 13, 2003 | 03:36 PM
ninesecteg's Avatar
Default Re: Piston to Cylinder clearance wrong? (b18bturbo)
take it to a machine shop and have them measure it. and if the clearances are to tight then send ge the bill!
Old May 13, 2003 | 03:38 PM
Flamenco-T's Avatar
where did you measure it ? I mean, how far down on the piston skirt, did you measure it against the cylinder wall ?
stan
Old May 13, 2003 | 04:11 PM
B20LS-T's Avatar
New User
Default Re: Piston to Cylinder clearance wrong? (ninesecteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecteg &raquo;</TD></TR><TR><TD CLASS="quote">take it to a machine shop and have them measure it. and if the clearances are to tight then send ge the bill!</TD></TR></TABLE>
Yeah, I was going to call GE and complain and try and get a refund, after all it is their F-up
Old May 13, 2003 | 04:13 PM
B20LS-T's Avatar
New User
Default Re: Piston to Cylinder clearance wrong? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">where did you measure it ? I mean, how far down on the piston skirt, did you measure it against the cylinder wall ?
stan
Not sure what you mean, but I measured the bore of the cylinder in three locations top/bottom/middle, then compared it to the measurement of the piston diamater.
I probably should have the machine shop look at it to get more accurate measurements, but I want to get my money back first
Old May 13, 2003 | 04:17 PM
B20LS-T's Avatar
New User
Another thing I though of, I already did my ring end gap for one piston, does this mean its gonna be fuked up when i get it bored another .0020" or so?
5_Lug_B
Aug 5, 2007 09:26 PM
giomfe
Nov 19, 2006 09:00 AM
AgentJam
Jul 22, 2004 06:22 PM
ludelvr
Nov 26, 2003 03:56 PM
crxhybrid1320
Feb 2, 2003 12:50 PM
