Overheating Problems After Piston, Rods Install
Old Apr 18, 2005 | 02:35 PM
GorData's Avatar
Default Overheating Problems After Piston, Rods Install
I am having problem with My 1.8 Dohc Vtec With Drag Turbo Kit. Last week I installed JE 9.1 Pistons and Scat rods. I also Installed New Oil Pump, Water Pump, OEM Headgasket, GE Headstuds. I drove the car for like 1 week after Install and Yesterday the Weather Was in the 70's and I was driving in Stop and go traffic and the temperature started to go Up, it went up pass Half and then I stopped. and I let it Idle. The car smells a little like antifreeze in the cabin. Today I changed the the thermostat, thermoswitch and I bleed the system. After I changed all that I drove for like 40 Minutes and I got to where I was going and it did it again. What could It be. I checked the Oil Cap and there is No Milky stuff there, The fans are coming on like they are suppose to. Could it be that I need the head retorqued??
Old Apr 18, 2005 | 03:01 PM
ProjectDarkBlack's Avatar
Default Re: Overheating Problems After Piston, Rods Install (GorData)
that could be a blown headgasket, or air pockets in the head. Make sure you retorque the headbolts after 500 miles
Old Apr 18, 2005 | 03:11 PM
EJ1 wilcox's Avatar
Default Re: Overheating Problems After Piston, Rods Install (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">that could be a blown headgasket, or air pockets in the head. Make sure you retorque the headbolts after 500 miles</TD></TR></TABLE>
I was told to retorque the head studs after 10 heat cycles...
I would try that, and see if it helps...
Old Apr 18, 2005 | 05:00 PM
GorData's Avatar
I am going to try to Retorque the head but I dont think it has a blow headgasket cause its not Mixing Or anything and the thing has only like 300 miles. The car runs Fine, and its weird cause I cant pin it down on when it does it, Cause it doesnt do it after I drive Hard or When I am crusing.
Old Apr 18, 2005 | 05:23 PM
GorData's Avatar
how would I check if the head has airpockets??????
Old Apr 19, 2005 | 06:39 AM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GorData &raquo;</TD></TR><TR><TD CLASS="quote">how would I check if the head has airpockets??????</TD></TR></TABLE>
I don't think the head can have air pockets... there might be air in your coolant, which lowers the boiling temp and could cause you to overheat...
Just run your car with your radiator cap off and your heat all the way on until there are no more bubbles in your coolant... make sure to top it off too...
Old Apr 20, 2005 | 05:09 AM
GorData's Avatar
Default Re: Overheating Problems After Piston, Rods Install (EJ1 wilcox)
I found the Problem, It was that the Radiator Fan was Trying to Push air threw the radiator instead of pulling it threw.
Old Apr 21, 2005 | 09:21 PM
it can have air pockets, thatswhy there is a bleeder valve uptop
Old Apr 22, 2005 | 04:14 PM
GorData's Avatar
Not all year Integra's have a bleed screw Up top. Mine doesnt have it. and its a 96.
Old Apr 22, 2005 | 04:20 PM
BEEYOND's Avatar
bad install
Old Sep 15, 2005 | 04:49 PM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">it can have air pockets, thatswhy there is a bleeder valve uptop </TD></TR></TABLE> where is this valve?
BLUE EH3's Avatar
Help we my pennies
how did u find this out?
boostedjdmdc2
Jan 10, 2009 07:46 PM
GorData
Jul 25, 2005 01:44 PM
EKB18BPR3
Jul 9, 2004 08:20 PM
Boosted_MRCSI
Jun 16, 2004 02:38 PM
M.A.R.C.
Sep 11, 2002 07:44 PM
