eagle rods with CP pistons...for those who have these set-up
ok im about to install eagle rods with CP pistons. am i supposed to install spacers on the dowel pin on either side of a rod? i dunno how to explain well. im concerned because theres so much side to side play when the rods are on the pistons.
also how do i take the OEM dowel pins out of OEM pistons? looks like theres 2 dowel pins per piston/rod.
sh!t happens.
Re: eagle rods with CP pistons...for those who have these set-up (98B00STED)
i have cp pistons and eagle.. but have not installed yet.. next week.. but bump for some one to help you.
Re: eagle rods with CP pistons...for those who have these set-up (karmannghia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED »</TD></TR><TR><TD CLASS="quote">ok im about to install eagle rods with CP pistons. am i supposed to install spacers on the dowel pin on either side of a rod? i dunno how to explain well. im concerned because theres so much side to side play when the rods are on the pistons.
also how do i take the OEM dowel pins out of OEM pistons? looks like theres 2 dowel pins per piston/rod.</TD></TR></TABLE>That is what those little sprung steel C clips are for. You got 8 of them. They fit into the grooves cut into the piston pin area. They hold the piston pin in place so it won't slide out and hit the cylinder. You install one of them in the piston, slide the pin thru the other side and through the rod. Then install the C clip on the other side. This is going to be hard for you to do the first time. Be careful the C clip does not go flying out on you as you do this. As to rod placement, the bearing tang sides face to the exhaust side.
As to your stock pistons the pins must be pushed out with a press.
Re: eagle rods with CP pistons...for those who have these set-up (earl)
thanx earl. the c clips were hidden behind the foam stuff at the bottom.
Rockin custom CP's and eagles for 400 miles now in my F22 - so far so good. Thumbs up to Earl, helped me out on which way the bearing tangs faced too
Vagitarian
09-14-2012 02:14 PM
StupidSlowRSX
01-27-2005 08:37 PM
