Problems after turbo install
Old Jan 7, 2009 | 07:10 PM
boostedjdmdc2's Avatar
Default Problems after turbo install
Just finished installing my kit. Took it out for a spin, everything sounded fine, turbo spooled nice and loud. Car started to get hot so I took it home. Pull in my garage and my radiator bursts. Kinda figures this would happen cuz it was leaking a little. Took off my oil cap and noticed a milky type fluid on the cap. this morning I went out to start my car up and noticed some water coming out of the downpipe, I've heard This can cause a milky type oil. Also my bov wasn't working. Maybe tapped wrong vaccum tap? Any ideas?
95 integra gsr
T3 t4
Old Jan 7, 2009 | 07:23 PM
miguel329's Avatar
Default Re: Problems after turbo install
was the car tuned?
Old Jan 7, 2009 | 07:25 PM
LVB18Civic's Avatar
Sounds like a blown head gasket. Like above, was it tuned when you took it out?
Old Jan 7, 2009 | 07:27 PM
I have a basemap on it with a 5 pound cut off til I get it dynoed
Old Jan 7, 2009 | 07:50 PM
90blackcrx's Avatar
Sounds like the head gasket is blown.
Old Jan 7, 2009 | 08:11 PM
GT35R_EF's Avatar
Make mine whatever you want
x2... Hot + Milky Oil = ^^
Old Jan 7, 2009 | 08:32 PM
Could it happen so quick like that? Wasn't milky before install but I guess I didn't really look for it
Old Jan 7, 2009 | 09:48 PM
TehGhett0P1mp's Avatar
You HG blew because you beat on a car with a basemap that was designed to get it to the tuner...
Old Jan 7, 2009 | 10:55 PM
even with a five pound boost cut? i mean i didnt really BEAT on it.
Old Jan 7, 2009 | 11:08 PM
the temp gauge never got to 3/4 hot. only went a little above half way
From what I have read and discussed with my tuner personally is that on basemaps you should try not to even enter boost. From what I have seen on here sometimes basemaps are spot on and work fine, other times they just get the car started and off to the tuner. Without having everything put in exactly without guessing I personally wouldn't do anything wreckless..
Old Jan 8, 2009 | 05:46 AM
supraccordlx's Avatar
Even w/5lbs of boost you blown your head gaskets. You prob boosted a 180k civic, the head bolts could have been not torque right, or the head gasket was on it's last leg then once the car since pressurize air then bye bye head gasket.
Or you reamed on it w/a base map like 98% of kids do.
Old Jan 8, 2009 | 10:29 AM
where did you come up with this 180k civic? im leaning towards the gasket was on its last leg and once i entered boost it went. is there any test i can be for sure?
Old Jan 8, 2009 | 11:59 AM
HarfordCTR's Avatar
^ yes, a leakdown test, or even compression test to start with
Old Jan 9, 2009 | 04:42 AM
dpetro1's Avatar
lol at everyone pointing straight to a headgasket. thats the worst case and very possible but at least cehck some smaller things first. fix your radiator, change your oil and coolant, bleed the system. do a leakdown and comp test and see what happens. if the car continues to get hot and mix fluids then go for a headgasket change.
Old Jan 9, 2009 | 05:12 AM
blaze the chemi's Avatar
In order to do a compression test you must have the car warmed up to operating temperature. Doing that while you are already leaking fluids is a bad idea especially with a non working radiator. Get that fixed and change the coolant and oil. Hopefully they won't mix again. Please get you car tuned before having fun with it. The temptation is great, but pretend your car has a nasty STD and your tuner has the cure to rid the disease. Then have fun!
Old Jan 9, 2009 | 06:25 AM
turboteg2nv's Avatar
LOL best advice I've seen in a while.
Old Jan 10, 2009 | 07:45 PM
well replaced the headgasket today and installing the new radiator tomorrow. new oil new coolant, hope for the best
Old Jan 10, 2009 | 07:46 PM
very well put lol
boosted_EM1
Apr 16, 2007 10:42 AM
boosted_EM1
15
Apr 8, 2007 12:53 PM
T-RO
Jun 28, 2004 03:05 AM
M.A.R.C.
Sep 11, 2002 07:44 PM
