over flow can problem?
Old Sep 10, 2006 | 06:54 PM
ALL IMPORT's Avatar
Default over flow can problem?
i have a gsr motor built ect running a big *** turbo with 18psi making 370whp.
did comp test & leak down & everything is good.
so i took the valve cover vent & the top vent off the black box on the back of the motor ran the 2 lines to the drivers side of the car where the washer box was & using the greddy can that u can see the oil line. i ran both lines together with a y connector about 5in from the can then on the other side of the can stuck a little filter. but this thing fills up fast. within 2 runs down the track its basically full. then driving around town within 20 miles have to drain again.
do i need more vents or what.
wtsapexipowerfc
Nov 18, 2010 09:47 AM
91teg6908
Oct 26, 2010 07:39 AM
Art701
15
Oct 25, 2004 06:25 PM
Art701
Oct 22, 2004 05:24 PM
5thgencivic
Jan 31, 2004 10:55 PM
