Catchcan smoke
Old Jan 31, 2004 | 03:40 PM
5thgencivic's Avatar
Default Catchcan smoke
My motor is freshly built. I recently hooked up a catchcan(about 200 miles ago). The motor hasn't seen boost yet. Some very light smoke vapor is coming from the catchcan breather(smells like fuel). It only started after what I thought was some spilled fuel that somehow ran into the "black box" line when I changed injectors. So I pulled the catch can today and cleaned it. There was some liquid, almost like fuel. No oil at all. I cleaned the filter and everything... Still some smoke(I'll probably pull the box off tomorrow and clean it).
I never got any smoke before the catch can install with the breather on the valve cover. I have it setup with the valve cover line going to the catch, line from the black box to the catch, and a breather on top. No PCV. Weird thing is it didn't smoke when I first installed it either.. hmm. Any help is appreciated. and yes I searched one person had the exact problem but an answer was never given.
Nate
Old Jan 31, 2004 | 06:26 PM
99B16Si's Avatar
is the catch can venting off the head or block?
Old Jan 31, 2004 | 09:01 PM
Default Re: (99B16Si)
both. it's set up like the endyn catch.
Old Jan 31, 2004 | 09:03 PM
V-SPEC 1's Avatar
Default Re: (5thgencivic)
It just a little blow by is what I think. Mine does it to.
Old Jan 31, 2004 | 09:50 PM
Default Re: (boostedb20vtec)
Ok, I've heard some say it's normal for a little so I shouldn't worry about it I guess
Old Jan 31, 2004 | 10:09 PM
Sprockets's Avatar
Could it just be moisture? Although I don't have an Endyn type setup, my pneumatic catch cans were working fine during the summer and fall months, but once winter hit, I started collecting fuel smelling moisture + oil.
Old Jan 31, 2004 | 10:55 PM
Default Re: (The Dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Dude &raquo;</TD></TR><TR><TD CLASS="quote">Could it just be moisture? Although I don't have an Endyn type setup, my pneumatic catch cans were working fine during the summer and fall months, but once winter hit, I started collecting fuel smelling moisture + oil.</TD></TR></TABLE>
Could very well be! It rains almost every day here during the winter, plus stays around 40* or so, so that could be it
93 Eg Couper
Oct 4, 2010 01:24 AM
cslegacy
May 16, 2008 08:35 PM
d!zZy
Feb 25, 2004 07:38 PM
pg_thao
May 21, 2002 03:52 PM
