open loop vs. closed loop wastegates?
Old Jul 21, 2003 | 10:55 PM
booja's Avatar
Default open loop vs. closed loop wastegates?
i know i would gain power by dumping into the atmosphere b/c my dumptube is to close to the turbo...
but does it matter if i'm running an open downpipe? if it does how much power am i losing b/c its a closed loop set up. i wanted to redo it but i can't figure out where to make the dumptube go. is it worth redoing?
Old Jul 21, 2003 | 11:06 PM
TwistedHatch's Avatar
Default Re: open loop vs. closed loop wastegates? (booja)
i'm interested in knowing this also, i know there has been alot of talk about it, i'm redoing my setup wich was closed, now it will be open just cause it might make more power and also cause i'm getttin a new dp and it's just easier to make it open instead of closed........
Old Jul 21, 2003 | 11:11 PM
TeStUdO's Avatar
well first off i would get rid of that wastegate. then i would dump it into open atmosphere or change it to dump back in 18" away from turbo. i think thats the right length. somone else back me up
Old Jul 21, 2003 | 11:26 PM
psileepR's Avatar
New User
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">well first off i would get rid of that wastegate. then i would dump it into open atmosphere or change it to dump back in 18" away from turbo. i think thats the right length. somone else back me up</TD></TR></TABLE>
get a tial... deltagates = boost creep
Old Jul 22, 2003 | 04:30 AM
symba's Avatar
Old Jul 22, 2003 | 09:21 AM
booja's Avatar
yeah... i've heard this wastegate creeps... but it has not happened to me yet. it came w/ the kit so i used it... but imma buy a tial soon.. i was already planning on it b4 i even put the turbo on.
Old Jul 22, 2003 | 09:43 AM
shermanyang's Avatar
Default Re: (booja)
i had a deltagate...freaken center shaft shattered on me leaving the wg wide open during first track run!!! damn cheap POS!! just got my new Tial 38mm WG today!! compared center shafts...damn the Tial is 4 times thicker!! now that's what i call quality!!
Old Jul 22, 2003 | 10:12 AM
iiilgsrlll's Avatar
Default Re:
I remember a while back when Super Street (I think) did a test on a Prelude FMAX kit. The HP differential between closed and open loop was 20-30hp. I do not remember the exact figure but I vaguely remember the upper figure was 244hp. If anyone has the article still please verify.
Old Jul 22, 2003 | 12:00 PM
JDMCRX's Avatar
Default Re: Re: (iiilgsrlll)
Ive seen 2 cars they tried both and with the open loop the car gians alot more power on a 521hp civic made 540ish with it pluimbed out.
Old Jul 22, 2003 | 01:10 PM
gritsak's Avatar
Default Re: Re: (JDMCRX)
yeah the way you have it set up now doesnt look to good...just think of all the exhaust gas coming out of the turbo flowing through the exhaust...then the wastegate opens and slams gases sideways against them causing a bunch of turbulance.
if you are going to plum it back in, do it furth down the exhaust and try to make it so the flow of the dump tube goes with the flow of the exhaust.
Old Jul 23, 2003 | 05:11 AM
BodyKits NW's Avatar
Default Re: Re: (gritsak)
Even if you have it plumbed back into the exhaust farther down you would still see a decrease in HP. So basically there is no way to run a closed loop setup and see similar HP numbers to a open look?
Old Jul 23, 2003 | 05:52 AM
Honda Hick's Avatar
test it out for us when you do it. If you can get on a dyno now and see how much HP you are then do it again after you do open loop or run it further down the exhaust.
Old Jul 23, 2003 | 06:09 AM
symba's Avatar
I don't know if it's possible to have absolutely NO power loss. But you can keep it to a minimum by doing what was said above. Introduce the dumptube further down into the downpipe (closer to the cat) and reduce the angle at which it merges with the downpipe.
That's why the FMax test on the Prelude showed such a difference. The dumptube was at a horrible angle and too close to the turbo.
Old Jul 23, 2003 | 11:13 AM
booja's Avatar
it is a modified drag manifold...
i was told by many that my hp is suffering b/c of this. so i'm currently redoing it. as far as comparing the 2, i cant b/c when i'm putting my car on the dyno this friday i'm getting my hondata tuned and i will be running open downpipe. so comparing would be useless.
Old Jul 23, 2003 | 08:46 PM
Default Re: (booja)
Great, let me be the guinea pig.
Old Jul 23, 2003 | 08:52 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">yeah the way you have it set up now doesnt look to good...just think of all the exhaust gas coming out of the turbo flowing through the exhaust...then the wastegate opens and slams gases sideways against them causing a bunch of turbulance.
if you are going to plum it back in, do it furth down the exhaust and try to make it so the flow of the dump tube goes with the flow of the exhaust.</TD></TR></TABLE>
I couldnt agree more. The way you have it is probably causing a power loss, and that is probably the only thing that will create a power loss in the never ending open/closed dumptube debate. The way i was taught, if its done correctly, it does not matter (performance wise) if its open or closed loop. But if i WAS to close-loop it, Id keep it about 14-18 inches away, and id make it a 45 degree angle bend into the downpipe. The way you have it now, as stated earleir, is going to create turbulence.
Old Jul 23, 2003 | 09:40 PM
InTeGrA B18b1's Avatar
Default Re: Re: (SIXTYdashONE)
i run a drag manifold with open downpipe w the deltagate no boost creep at all. but i ported my wastegate hole, i guess that helps a lot
stalyun
Apr 28, 2009 08:59 PM
EK FLY
Jul 8, 2006 06:26 AM
quik sol
Apr 18, 2004 07:08 AM
TurboDANDEE
Mar 26, 2003 03:34 PM
bgod
Aug 13, 2001 09:43 PM
