only making .5 lbs of boost what do I do?
Old Jun 22, 2006 | 07:48 AM
saywhat's Avatar
Default only making .5 lbs of boost what do I do?
Do I need to plug any lines that go to the evap canister or anything? I checked my couplers and all my connections from the turbo to the throttle body are pretty tight I just don't know where I am loosing boost, it is a t25 and when i sit and rev it in neutral it just can barely make it to half a pound. What do I need to do?
Old Jun 22, 2006 | 08:26 AM
Danny_EJ's Avatar
drive the car, put it under load
Old Jun 22, 2006 | 08:29 AM
VTteg's Avatar
Default Re: (Danny_EJ)
are you sure your gauge is in psi and not bars?
Old Jun 22, 2006 | 08:41 AM
saywhat's Avatar
Default Re: (VTteg)
it says 'press' on the guage I am assuming it is psi because I don't know anyone that would ever run 20+ bar. So under load it should boost more? or what difference would it make over neutral? I remember my old saab would only boost under load but I thought it was just the way that car worked. sorry for the stupid q's just new to the turbo world.
Old Jun 22, 2006 | 08:55 AM
1boostedcivic's Avatar
Default Re: (saywhat)
yeah most cars only go into boost under load. However i can hear compressor surge when i rev in neutral.
Old Jun 22, 2006 | 09:10 AM
saywhat's Avatar
Default Re: (1boostedcivic)
I guess I will have to drive it then, I just didn't want to put it on the road until I was sure everything was working ok, this is good, I was thinking it would be something worse, I will let you guys know if it solves the problem, Thanks
Old Jun 23, 2006 | 10:01 AM
jacka$$'s Avatar
Well how much boost under load did you get?
Old Jun 23, 2006 | 10:50 AM
importdude2000's Avatar
soapy water in spray bottle
srpay all couplers
and vacs
to find leak
Old Jun 23, 2006 | 12:33 PM
saywhat's Avatar
Default Re: (jacka$$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacka$$ &raquo;</TD></TR><TR><TD CLASS="quote">Well how much boost under load did you get?</TD></TR></TABLE>
I haven't driven it yet, but I now realize how dumb my question was, I will let you know the numbers when it is done
Old Jun 27, 2006 | 08:37 AM
saywhat's Avatar
putting down 5 pounds easy, just need to clean up my street tune.
turbotime
Oct 6, 2005 05:54 PM
r1lorenzini
Feb 19, 2004 11:54 AM
VTC_CiViC
Dec 19, 2003 06:05 AM
Hoodwinked
Sep 2, 2003 06:37 PM
Andrew 825SM
Oct 2, 2002 07:39 PM
