Okay to use walbro 255 till I boost???????????
Hey guys I need to replace the pump in my car now can I just put a high flow one in till I go boost? Also what is the one I should order for my 92 civic??????
Thanks
Thanks
Re: Okay to use walbro 255 till I boost??????????? (Ridinlowcivic)
I have been running it for about 1000 miles no problems. I plan to hook up the turbo in about a week or two. But so far it runs fine, I dont see why there would be a problem.
Re: Okay to use walbro 255 till I boost??????????? (Prelude Vtec 23)
I've had my walbro in my prelude for about 15k miles with and without turbo with no problems other then the fact that it is noisy when the tank is more then half empty and at stop lights.
Re: Okay to use walbro 255 till I boost??????????? (hybridreams)
You'll be fine walbro 255lp high pressure
I bought my car with it, and put turbo on 10 weeks later
Re: Okay to use walbro 255 till I boost??????????? (SilverCivic2k)
walbro 255 pum in my 95 civic b16a, stock pump stock fpr at idle was like 36-38 when pump was installed it jumped to 40 which is not too big of difference but ran it like that for a month or so no problems, you'll just hear the wine of the pump from time to time but no biggy, about to throw that same pump in my crx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCivic2k »</TD></TR><TR><TD CLASS="quote">Are any of you guys running a walbro with stock fpr?</TD></TR></TABLE>
I am. On my old motor I had a b&m fpr. On this motor right now I have the stock fpr.
Re: (jdm2916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2916 »</TD></TR><TR><TD CLASS="quote">where is the best place to buy a walbro fuel pump?</TD></TR></TABLE>
I got mine from Lightning here on the board.
Re: Okay to use walbro 255 till I boost??????????? (EGJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGJDM »</TD></TR><TR><TD CLASS="quote">Hey guys I need to replace the pump in my car now can I just put a high flow one in till I go boost? Also what is the one I should order for my 92 civic??????
Thanks</TD></TR></TABLE>
You will need to purchase the Walbro GSS342 fuel pump for your hatch. It should come with the Walbro install kit 400-846. Good luck.
Re: Okay to use walbro 255 till I boost??????????? (R6Elmo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6Elmo »</TD></TR><TR><TD CLASS="quote">no problems. stick that sucka in</TD></TR></TABLE>
oh yes, I definitely concur
Carlos 88CRXSi
11-12-2010 10:16 AM
squeaky
05-14-2002 07:07 PM
