oil turbo problem
Old Jan 13, 2005 | 07:17 PM
jcivic33's Avatar
Default oil turbo problem
what up peeps, I dropped my car off at honda to switch out a head. when i get the car back it was kicking put smoke. Checked the the lines to see if anything was pintching, nothing. took off the intercooler and found oil. turbo stops boosting
at .47bars when it used to hit .68bars no problem. and its stuggling after 4500rpm.
any ideas what it could be.
Old Jan 13, 2005 | 07:23 PM
honhatchisbak's Avatar
Default Re: oil turbo problem (jcivic33)
maybe not enought fuel, what kind of engine mangement you running, are u on fmu, it could also be that u have bent valves and stuff, happened to a good friend of mine
Old Jan 13, 2005 | 08:07 PM
jcivic33's Avatar
Default Re: oil turbo problem (honhatchisbak)
thats why i replaced the head due to a slightly bent valve when timing slipped.
but it ran stronger with the bad head. im running an s-afc, dsm 440 injectors/w resistors), new internals. ill have urbandata next month
Old Jan 13, 2005 | 08:32 PM
Tchleung's Avatar
Are you sure they timed your cam(s) correctly?
Old Jan 14, 2005 | 11:15 AM
jcivic33's Avatar
Default Re: (Tchleung)
ill have them recheck it
thanks
92jdmhatch
Oct 7, 2006 04:43 PM
REBEL69
May 19, 2005 01:38 PM
CRAZYHONDA
Apr 25, 2005 01:30 AM
siksivik
Jun 10, 2004 07:25 AM
thehondaguru
Jun 9, 2004 06:09 PM
