Oil Temperature? When is it too Hot?
Old May 16, 2008 | 01:08 AM
RedneckRicer's Avatar
Default Oil Temperature? When is it too Hot?
Looking to buy a Oil Cooler soon just for the Just in case factor. But i would like to know when is the oil too hot? i am going to be using Mobil1 10-40.
Old May 16, 2008 | 06:37 AM
sp00led's Avatar
Default Re: Oil Temperature? When is it too Hot? (RedneckRicer)
Once you get over 120C you are starting to push it. Some guys see 130C+ but I'd worry about running it like that for extended periods of time. It is putting wear on your motor and also causing you to lose power.
Old May 16, 2008 | 09:31 AM
anymore input?
Old May 16, 2008 | 10:48 AM
sp00led's Avatar
Default Re: (RedneckRicer)
I'm running a setrab oil cooler with a mocal sandwhich adapter with built in thermostat. -10an lines. Fittings and hoses will cost you as much as the oil cooler...
delux247
Honda S2000
Jan 4, 2004 07:01 PM
90crxzc
Dec 6, 2003 01:36 PM
SoulSurfer
Nov 8, 2002 06:22 AM
DreamSpeed
Jul 5, 2001 09:48 PM
