oil return on a top mount...where to run it
i have a AFI top mount and im running into the problem of how to run my return line. Is it ok to run the line through the manifold or do i have to run it another way? im not sure about what way to do this.....plz hlp me out
this is the mani. i have
http://www.afiturbo.com/store/produc...products_id=70
I had to run a 45deg -10 AN off the turbo going forward and to the side a bit to route it away from the manifold, then it curves down to a straight fitting into the top of the pan. It's not ideal, but I've had no problems.
This. Running straight down will cause it to sit against the manifold. Thats just going to melt the rubber hose inside. I'm also going to run a heat sleeve overtop of my hose.
BEEYOND
Sep 2, 2004 01:08 PM
Mr. Softee
Sep 18, 2003 08:09 PM
