Oil return line not connected?
Old Oct 29, 2004 | 03:11 PM
jnet's Avatar
Default Oil return line not connected?
Hi...I just noticed in my engine (h22) that a blue hose from the valve cover (the oil return line i believe) just hangs down into the engine, the other end is not connected anywhere. Is this normal? I know on stock cars the line usually goes into the intake, but this is a turbo setup.
Old Oct 29, 2004 | 03:22 PM
5l-eater's Avatar
Default Re: Oil return line not connected? (jnet)
yeah, if u hooked it back up to the charge pipe, the turbo would pressurize the crankcase springing oil leaks everywhere. Your best bet is to reroute it to the atmosphere thourgh a small filter or maybe a catch can?
Old Oct 29, 2004 | 03:59 PM
jnet's Avatar
Default Re: Oil return line not connected? (5l-eater)
ok...well I think i'd just keep it hanging there because nothing seems wrong with the car like it is. sometimes a little smoke comes out of that line at idle when the engine is cold, is that normal?
Old Oct 29, 2004 | 06:53 PM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5l-eater &raquo;</TD></TR><TR><TD CLASS="quote">yeah, if u hooked it back up to the charge pipe, the turbo would pressurize the crankcase springing oil leaks everywhere. Your best bet is to reroute it to the atmosphere thourgh a small filter or maybe a catch can?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnet &raquo;</TD></TR><TR><TD CLASS="quote">Hi...I just noticed in my engine (h22) that a blue hose from the valve cover (the oil return line i believe) just hangs down into the engine, the other end is not connected anywhere. Is this normal? I know on stock cars the line usually goes into the intake, but this is a turbo setup.
I hope both you guys are joking, and neither of you own a turbo Honda.
Old Oct 29, 2004 | 07:22 PM
jnet's Avatar
Default Re: Oil return line not connected? (m R g S r)
uhm the other guy may be joking but i am certainly not. hopefully i dont have to list my whole setup for you to believe me.
Old Oct 29, 2004 | 07:42 PM
honda9369's Avatar
JUST TAKE THE HOSE OFF AND FIND A SMALL K+N FILTER AND PUT THAT ON IN PLACE OF THE HOSE. AND NO THAT IS NOT A OIL RETURN LINE.
T9U4ReBgO
Nov 25, 2007 02:44 PM
bboyfreeze
Apr 2, 2007 08:38 PM
2LiterTurboSeR
Feb 27, 2006 02:38 PM
civicek00
May 31, 2005 09:38 AM
slo_crx
Oct 6, 2004 08:30 AM
