oil return line off turbo?
ok got another question does the oil return line off the turbo have to be a straight shot or can it have a slight curve in it???? and the curve has to go up a slight bit?/
Re: oil return line off turbo? (T9U4ReBgO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO »</TD></TR><TR><TD CLASS="quote">what would happen if oil got backed up in the oil return line?</TD></TR></TABLE>
The turbo would smoke like a freight train and would end up going out.
There should be no 90 degree turns in the drain a 45 is ok and the inside of the return line should be no smaller then 13mm or 1/2 inch.
Man U FTW
Re: (fireman mike2288)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireman mike2288 »</TD></TR><TR><TD CLASS="quote">no oil means NEW turbo lol </TD></TR></TABLE>
Good thing that's what they were talking about
As long as the oil line is going downward, you should be ok. Try to avoid flat spots and curving back upward because oil will pool in those areas.
