oil return help. where does the oil level sit??
my car is smokcing because of the oil return
my -10 bung is welded at the top of the oil pan but thats still not above the oil level. if i take the oil return off 1 quart of oil will leak out of the oil return bung.
wont this cause my car to smoke? is something wrong here? i though the top part of the pan was supose to be above the oil level.
i'm running the stock p72 oil pan which holes 4 quarts which will be at the top dot on the sip stick
are all your oil returns above your oil level. meaning when you take the return line off no oil leaks out of the pan???
when the engine is running and oil is circulating then the oil level will be lower in the pan. as long as you have the bung as high up as possible then there shouldnt be a problem. is your line kinked at all? any pics that could help us out?
thers a picture floating around here showing the place perfect for the bung
i followed this guide
"Make the lowest point of the oil pan fitting approximately 1.1" (28mm) down from the topmost part of the oil pan flange"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">thers a picture floating around here showing the place perfect for the bung
well the "perfect" place is gonna be determined by your setup. different manifold and turbo configurations are gonna determine where you want your oil return. the best thing to do is mount your mani, turbo and dp and then find the best route for the return line. mark where you want the bung to go, then remove the pan and drill it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">
well the "perfect" place is gonna be determined by your setup. different manifold and turbo configurations are gonna determine where you want your oil return. the best thing to do is mount your mani, turbo and dp and then find the best route for the return line. mark where you want the bung to go, then remove the pan and drill it. </TD></TR></TABLE>
i meant up/down wise
of course where u tap left/right depends on ur manifold ull be using and dp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 »</TD></TR><TR><TD CLASS="quote">i meant up/down wise
of course where u tap left/right depends on ur manifold ull be using and dp</TD></TR></TABLE>
werd
werd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">Many people run oil returns at the very bottom of the oil pan (IE the drain plug). Therefor, your problem is not associated with the relative location of the oil level and the hole!</TD></TR></TABLE>
End of discussion.
End of discussion.
you are the first person I have ever heard say that.....
I dont know of anyone who runs their drain at that point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">you are the first person I have ever heard say that.....
I dont know of anyone who runs their drain at that point</TD></TR></TABLE>
i have heard of it before. i think some of the greddy kits run the return there. i dunno how i feel about it though. ill keep my return right where it is, nice and high.
Greddy kits return oil to the drain plug. They wouldn't do that if it could damge the turbo. You don't have to trust me you have to trust a large company that is willing to warrenty turbo's that drain oil to the lowest point in the oil pan.
D16y8_619
Sep 8, 2006 09:05 PM
