OIL pressure too high?
Old Mar 7, 2004 | 06:27 PM
Harassing Herbs's Avatar
Default OIL pressure too high?
i had a oil light yesterday so i installed a 2000- gsr oil pump on my 2000-b16 and the oil pressure gauve hoovers around 20psi at idle , when i drive at high rpm around 7grand its at 75-80psi. i know this is not normal or good for my oil seals in the turbo. is there anyway i could lower my oil pressure or would this problem just be a faulty gauge???? i have a sun pro 0-100psi oil gauge.
Old Mar 7, 2004 | 06:37 PM
lazerus's Avatar
Default Re: OIL pressure too high? (Harassing Herbs)
that oil pressure seems pretty normal, perhaps a little low idle pressure, but i dont know the specs!
Old Mar 7, 2004 | 06:42 PM
Default Re: OIL pressure too high? (lazerus)
i thought 15 psi at idle was normal and 65-70 psi at high rpm but if my readings are normal then im good.
Old Mar 7, 2004 | 06:50 PM
vtec.dc2's Avatar
idle mabye little high.. what type of oil is it btw. and do you have the pressure at all times, does it go down after some driving?
Old Mar 8, 2004 | 07:02 AM
Default Re: OIL pressure too high? (vtec.dc2)
its 10-30 weight oil and yea the pressure is like that after driving as well. stock b16a2 type r cams 00gsr oil pump
Old Mar 16, 2004 | 06:47 AM
R-Toyz.com's Avatar
Same pressure on idle and throttle as mine...and im running a stock GSR motor.
But then again my oil level is a bit above the high mark...so check your oil levels too. That may contribute to a 20ish psi at idle (assuming 15 psi is normal).
Old Mar 16, 2004 | 06:56 AM
b18bturbo's Avatar
Default Re: (rtzcom)
thats normal oil pressure reading dont worry about it.. what - line are oyu running to the turbo is it -3 or -4
Old Mar 16, 2004 | 07:03 AM
mchuang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harassing Herbs &raquo;</TD></TR><TR><TD CLASS="quote">i had a oil light yesterday so i installed a 2000- gsr oil pump on my 2000-b16 and the oil pressure gauve hoovers around 20psi at idle , when i drive at high rpm around 7grand its at 75-80psi. i know this is not normal or good for my oil seals in the turbo. is there anyway i could lower my oil pressure or would this problem just be a faulty gauge???? i have a sun pro 0-100psi oil gauge. </TD></TR></TABLE>
When Vtec comes on it should hit about 75 to 80 psi.
Old Mar 16, 2004 | 10:30 AM
-Trinitron-'s Avatar
http://www.atpturbo.com/Mercha...e=OIL
Old Mar 16, 2004 | 04:16 PM
Default Re: (b18bturbo)
i believe its a -4
Old Mar 16, 2004 | 05:09 PM
b18bturbo's Avatar
Default Re: (Harassing Herbs)
i would run -3 instead as well too much oil to the turbo is bad thing
Excusetobooost
Jun 9, 2020 01:19 PM
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
Monkey Fing a Coconut
Oct 31, 2004 05:29 AM
TurboCX
Aug 3, 2003 06:33 PM
