oil pan
Old Nov 13, 2005 | 06:24 PM
teddy_dc2's Avatar
Default oil pan
what do you guys use to seal your oil pan fitting? i got an AN fitting and using gasket maker red gel plus regular heat treated wahsers on both in and out of the oil pan, will this hold the an fitting?
Old Nov 13, 2005 | 06:28 PM
BlueShadow's Avatar
Default Re: oil pan (teddy_dc2)
You're not supposed to use any kind of sealant on AN fittings It gets its seal from the angled surfaces meeting together. However where my oil drain flange bolts to the turbo I use high temp solocone sealant. I dont use any sealant on the 1/2" NPT side that goes into that flange, but I probably will when I go to reinstall the turbo. And of course my AN fittings are clean with no sealant. On the oilpan I have a -10 AN steel weld on bung.
Old Nov 13, 2005 | 06:29 PM
komat's Avatar
take it to a machine shop and let them weld it on
Old Nov 13, 2005 | 09:32 PM
spoolinyo's Avatar
i use the moroso solved all my problems
fusion645
Mar 19, 2010 01:42 PM
B18c1turboedEK
Feb 21, 2005 10:32 AM
Sinner
Oct 8, 2004 09:21 AM
Vtec92Civic
Aug 21, 2003 08:36 PM
