Oil and liquid cooled T3
Old Nov 22, 2006 | 01:52 PM
DS002's Avatar
Banned
Default Oil and liquid cooled T3
Can i just use the oil to cool it , or do i have to use the liquid cooling as well .
Old Nov 22, 2006 | 01:53 PM
DS002's Avatar
Banned
Default Re: Oil and liquid cooled T3 (DS002)
oil should lubricate it and the coolant just helps temps right ?
Old Nov 22, 2006 | 02:11 PM
boosted.CRX's Avatar
The coolant prevents coking in the turbo.
Old Nov 22, 2006 | 02:14 PM
EJ1 wilcox's Avatar
Default Re: (SiRClay)
If your CHRA has a coolant jacket then I say run some lines.
It's easy and quick to do, and it gives you some added insurance.
I had water lines on my last setup and I would never idle it before I shut the car off. I was told that if you have a water cooled turbo that the coolant cools the turbo slow enough so that you don't need a turbo timer...
Anyways, I rebuilt the turbo after over a year of daily driving it like that and the bearings were still mint.
Old Nov 22, 2006 | 02:30 PM
DS002's Avatar
Banned
Default Re: (EJ1 wilcox)
yea i just dont have any fittings for it so i wanted to see if its really neccesary or not
Old Nov 22, 2006 | 02:33 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
yup, that's why almost all factory turbos are water cooled. It makes it easy to not mes up your turbo. You dont have to hook them up but know that it may make your turbo last longer if you dont let it cool down before shutting the motor off
Old Nov 22, 2006 | 02:35 PM
beepy's Avatar
Default Re: (DS002)
Sure it is. The only non-water-cooled turbos I have seen were either extremely old or for a diesel. I think running a turbo timer just because you were too lazy to buy a couple fittings is stupid.
DS002's Avatar
Banned
Default Re: (Bailhatch)
well either way im going to hook them up , but maybe for not a week or two so i wanted to make sure itd be alright wihtout them
Old Nov 22, 2006 | 05:16 PM
HiProfile's Avatar
Default Re: (DS002)
For some turbos, its not a matter of being lazy. The vast majority of new Garrett turbos use 3/8" npt, but some of the older T3's have a rediculous parallel metric thread that needs either a $60-85 banjo fitting, or in my case a copper seal and bolt welded to a home-made npt fitting.
Old Nov 22, 2006 | 05:18 PM
DS002's Avatar
Banned
Default Re: (HiProfile)
well this is an old garret T3 and no fittings i have fit , so i hope its not that expensive
11psiTurboSI
Dec 21, 2004 04:52 PM
the.hamburglar
May 1, 2004 07:13 PM
This One
Jan 14, 2004 06:06 PM
asianspeed
Jan 28, 2003 04:30 PM
DS1
Oct 4, 2002 08:21 PM
