oil line problem
Old May 3, 2004 | 02:56 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default oil line problem
would the oil return, going from the turbo to the oil pan if it was clogged/ jammed or krimped would it cause my car to smoke badly? tons of smoke. blue. i think this is the problem? im runnin 450's and afc. set back -40 across. anyone else know what could be makin my car smoke .the turbo is in decent cond. no shaft play. motor is strong. lemme know
Old May 11, 2004 | 07:38 AM
_HANS's Avatar
Default Re: oil line problem (NJHatch)
what sizes are you guys running for the oil return line(from the turbo to the oil pan)? would a smaller size line cause the car to smoke more than usual?
Old May 11, 2004 | 09:06 AM
Chillinit's Avatar
i'm running a -10 steel braided line. (5/8" ID). If you oil return is clogged or somehow not draining into your oil pan, you could see access smoke. Are you sure your engine is in good condition? compression/leak down tests?good luck
Old May 11, 2004 | 09:50 AM
sm00thk0zz's Avatar
Blue smoke... isn't that coolant?
Old May 11, 2004 | 09:51 AM
MikeMAN's Avatar
Default Re: (sm00thk0zz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sm00thk0zz &raquo;</TD></TR><TR><TD CLASS="quote">Blue smoke... isn't that coolant?</TD></TR></TABLE>
no, coolant is usally white heavy smoke.
but yes, a small return line can cause oil to backup in the turbo and blow the seals.
mike
Old May 14, 2004 | 01:25 PM
cheapturbolines.com's Avatar
What size return line are you running? Like mentioned above -10 is the proper size.
When does the car smoke? At idle? during WOT? or on deccel after WOT?
Old May 17, 2004 | 06:27 PM
_HANS's Avatar
Default Re: oil line problem (cheapturbolines.com)
smokes mostley at idle,WOT it doesnt smoke. low rpm mostley
Old May 17, 2004 | 06:44 PM
smoking at idle generally means the turbo is clogged up from either too much oil entering from too large of a feed line or too small of a return line not allowing the oil to drain. What size feed/return are you currently running?
chris G.
Old May 18, 2004 | 08:03 AM
_HANS's Avatar
3/8 black heavy duty fuel line return and 3/8 same type of hose feed
Old May 18, 2004 | 09:14 AM
jmagner's Avatar
generally your return should be larger than your feed. Make a -10 AN drain and a -3 or -4 AN feed and you should be all set, if of course your smoking problem is due to oil flow through the turbo.
Old May 18, 2004 | 09:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJHatch &raquo;</TD></TR><TR><TD CLASS="quote">3/8 black heavy duty fuel line return and 3/8 same type of hose feed</TD></TR></TABLE>
Well that is your problem. -3 oil feed, app. 3/16", and a -10 oil return, app. .5" would solve your oil burning problems.... The sooner you fix it the better cause you could end up w/ blown seals on the turbo and we both don't want that. If you need a feed return kit w/ the proper sized lines we can get you one.
Chris G.
Old May 18, 2004 | 04:47 PM
_HANS's Avatar
so if i keep my feed 3/8 and make the return bigger i shouldnt have a problem?
Old May 18, 2004 | 04:59 PM
Yes, you will still have a problem. A 3/8" feed is allowing way too much oil into the turbo even if you get the right size return to drain it. 3/16" is what you want for the feed.
Old May 18, 2004 | 05:07 PM
_HANS's Avatar
well i put a valve in the feed line,so if i crack it a little so less oil flows, and get bigger return line ill be good right?
Old May 19, 2004 | 06:00 AM
that should help reduce the oil flow so it should work..... but if you keep burning oil definitly switch to a 3/16" or -3 line.
hondaeg8
May 22, 2006 03:12 PM
TheIntegraGuy
Jul 28, 2005 08:28 AM
playAho
Apr 16, 2004 04:57 PM
MiraiZ
Apr 20, 2002 06:36 AM
EJ1B20B
Mar 27, 2002 05:29 PM
