oil light
Old Jun 7, 2007 | 08:39 PM
krazyhmongboi's Avatar
Default oil light
lately when im in high boost my oil light will flash real quick and today it flashed and flashed about 4 more times while getting dimmer each time..what could be the problem? i checked the oil and i have oil..=/
Old Jun 7, 2007 | 08:55 PM
inspyral's Avatar
Do you have an oil pressure gauge? The stock gauge only comes on at like <5psi or something ridiculously low, so if your oil pressure is low enough to trigger it, the damage might already be done. Is your feed line tee'd off the same source as the stock pressure sender?
Old Jun 7, 2007 | 09:01 PM
yea the feed line is tee'd off at the same source spot..no i dont have an oil pressure gauge yet
Old Jun 8, 2007 | 06:45 AM
dpetro1's Avatar
Default Re: (krazyhmongboi)
just because you have oil doesnt mean that you have pressure. you need to find out what is going on and hope that there isnt any engine damage. and get an oil pressure gauge asap. $60 can save your whole setup.
Old Jun 8, 2007 | 06:51 AM
ProPerformance's Avatar
Check the wiring to the sensor if it is grounding out it will flash at you..Also buy a guage asap
Old Jun 8, 2007 | 10:47 AM
koo thanks..i'll pick up a gauge asap..thanks again..then i'll check back in
sirtef9
Engine Machining & Assembly
Jun 8, 2017 04:56 PM
boostgegsr
Dec 6, 2011 07:01 AM
Turbo_y8
Apr 21, 2005 04:23 PM
W O T
Jan 29, 2005 08:01 PM
graphic
Dec 7, 2004 10:31 AM
