oil leak, how from here???
Old Apr 8, 2006 | 09:47 AM
zexifiedlude's Avatar
Default oil leak, how from here???
ok yesturday out of no where i started leaking a rediculous amount of oil, and bout an hour ago i jacked up my car to see where it was coming from and its coming from the fitting on the oil return on the oil pan
here is a pic:
is that just a bad fitting or what? it screwd on to the bung on the oil pan as tightly as possible. ok thanks
Old Apr 8, 2006 | 09:59 AM
HamiltonRex's Avatar
Default Re: oil leak, how from here??? (zexifiedlude)
You have that fitting matched to the proper fitting on the oil pan yes?
Old Apr 8, 2006 | 10:39 PM
yes
Old Apr 9, 2006 | 04:03 AM
inspyral's Avatar
Did you use teflon tape? The reason I ask is because AN fittings don't require thread sealing paste/tape and will leak if you use them.
Old Apr 9, 2006 | 07:35 AM
no no teflon tape
Old Apr 9, 2006 | 07:46 AM
stealthmode62's Avatar
Default Re: (zexifiedlude)
Take it off, clean it, and put it back on making sure it's tight. Because it's a spinning fitting, it seals the back of it (where you circled) only when it's tightened onto the fitting.
EG6 Love
Sep 6, 2015 02:30 PM
riceball777
Jul 27, 2006 11:33 AM
B18c1turboedEK
Feb 21, 2005 10:32 AM
Sinner
Oct 8, 2004 09:21 AM
GruvyTune
Nov 18, 2001 03:59 PM
